Hi,
Just noticed my 33 has a bit of a fuel leak after being able to smell it in a big way every time I filled up
after having a look underneath I can see that it is actually laking as I can see where it appears to have been fuel running down the tank and over all the rear suspension bits.
Question is, is it common for these tanks to crack at all? Im thinking highly unlikely although just wanted a bit of a heads up before i start pulling stuff apart. at this point im thinking its coming from the top screw cap that you open to get to the fuel pump.
Any ideas/experiences?
cheers
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/
I'd check the rubber o ring out that the fuel pump is under, and easy say 20 minute fix.
Also check around the filler cap area, when they comply the cars they have to install an ADR approved cap, some compliance guys just cut and shut but don't reseal. Check if your cap etc will spin if you twist it? If it does its just sitting there and neads resealing. Use a product called Sikaflex and it will reseal the compliance cap to the original filler neck. Its a urethane based product, so have heaps of rags handy and clean up with WD40. Don't use it on your o ring etc because once its set, you'll never get it apart again.
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4100560
Has anyone heard of fuel tanks cracking? thats my only stress at this point.. seals i can fix easy enough
Yeah, usually happens a) if a car has been off road and tank is slammed on roads of something b) as mentioned above if the car has been hit. c) older car
also I've heard of people drill holes in theirs by accident.
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4106875
  • 1 month later...
Having the same problem. Checked the O-ring and sure enough that needed replacing. That got back the woosh sound when opening the tank, however the smell and leak remained. So I jacked up the car to check where it was leaking from (since the filler neck showed no signs of leaking) and it appears to be leaking from where the filler neck meets the tank. Any advice would be much appreciated.
Thanks, Josh
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4202439
If its not structurally damaged, if it is still solid, I'd just use some tank sealer putty. You can get that at Repco or whatever, will work easy, just smear it on and push/work it in around the critical area. Its made for quick repairs on fuel tanks.
If its flexing and looks like it will get worse, its a tank out job. There are shops around that will weld a tank up, I 've done it before myself, you drain it, let it dry out, find a diesel motor and start it up, feed the exhaust fumes into the tank with a hose and while it is running, weld the tank up [mig is best, but oxy will work as well, arc is too much for the thin metal of a tank unless your a genius welder]. The exhaust fumes stop any big bang, they are carbon monoxide/dioxide plus other stuff and stop or supress any flame. A petrol engine will also work, but its not quite as safe. I've heard of guys using CO2 bottles as well.
An alternative to that is someone with a big soldering iron and solder it up. I've never seen fuel fumes ignite off a hot soldering iron. But soldered joints are not as strong as weld, but they can be pretty strong, many solder repairs have lasted years on fuel tanks and radiators.
A word of caution, its not for the novice [practice on something else] or the faint hearted, so if you can't weld don't try it yourself.
The last alternative is another tank, but who's to say it won't happen again.
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4202712
84ULP is the part number a cpc fuel cap. i think they are about $20 from your local auto store.
replacing the cap reduced the smell of fuel on my car, but still *shhhhhhhhhhhh* on a hot day. fuel does evaporate at a very low temp so i dont worry about it too much, worst things is having highly compressed fumes in your car and getting a static spark when u are fueling up, so losing approx 20ml of fuel through a non tight cap isnt much of a waste/risk.
btw how many kms do u get out of a full tank?
Edited by philta
https://www.sau.com.au/forums/topic/233926-fuel-leak-r33/#findComment-4207211
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
