Hey guys, ill be replacing my shocks in the r33 gtr today, and would like to confirm the torque settings for the bottom strut nut (the really tight one connecting to the eyeball).....and the two top nuts of the struts (in the parcel tray area)...
Also need to know wheel nut torque specs....
I dont have a handbook on me....
BUMP - just to clarify firther...the bottom stut nut is the 17mm one with the washer....and the two top strut nuts which are 14mm......always really paranoid about correct torque settings for these as its suspension!!!...
Also, what are good torque settings for spacer to hub nuts?....alot of people say to tighten them as much as you would a wheel nut....but i cant seem to get them that tight .....
Thanks!!!
Thanks....so basically even the spacers dont have to be torqued up to the hub ... but just at a tight setting.....
Indeed. Pretty much anything other than engine/g-box just needs to be "Tight" :P
Thanks - what would be considered tight though?....just hand tight...tight to a point where it feels like it definitely wont come loose?
Well they are pretty large bolts, so im guessing your using a 1/2" Socket set, so do it up as tight with the ratchet as you allow yourself (i hate straining the ratchet), then put the breaker bar on and just tweak it (without excessive force) untill it doesnt tweak anymore.
Basically put your hand on the socket over the nut/bolt, hold the breaker at the end and pull it towards you till its difficult, reposition the socket again, and do it again. You'l get the feel of it.
    • It's not any meta data. They have scraped images from everywhere, and then use AI to compare your photo to other photos and work out where you are.
    • I just looked at my camera phone settings, apparently I have "not allowed" for location  Will that stop that app?
    • Can you not just turn it off on your phone if required? I remember a brief on this, well, I remember the brief, not what to actually do. LOL
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
