Hey guys, ill be replacing my shocks in the r33 gtr today, and would like to confirm the torque settings for the bottom strut nut (the really tight one connecting to the eyeball).....and the two top nuts of the struts (in the parcel tray area)...
Also need to know wheel nut torque specs....
I dont have a handbook on me....
BUMP - just to clarify firther...the bottom stut nut is the 17mm one with the washer....and the two top strut nuts which are 14mm......always really paranoid about correct torque settings for these as its suspension!!!...
Also, what are good torque settings for spacer to hub nuts?....alot of people say to tighten them as much as you would a wheel nut....but i cant seem to get them that tight .....
Thanks!!!
Thanks....so basically even the spacers dont have to be torqued up to the hub ... but just at a tight setting.....
Indeed. Pretty much anything other than engine/g-box just needs to be "Tight" :P
Thanks - what would be considered tight though?....just hand tight...tight to a point where it feels like it definitely wont come loose?
Well they are pretty large bolts, so im guessing your using a 1/2" Socket set, so do it up as tight with the ratchet as you allow yourself (i hate straining the ratchet), then put the breaker bar on and just tweak it (without excessive force) untill it doesnt tweak anymore.
Basically put your hand on the socket over the nut/bolt, hold the breaker at the end and pull it towards you till its difficult, reposition the socket again, and do it again. You'l get the feel of it.
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
