I just took my car down for a wash just the drive thru high pressure one (no rollers) while it was going i noticed a large stream of water running into the back cargo area. It looks like it is coming from one of the child restraints that were fitted during compliance i cant see how it got down into there in the first place any ideas has anyone else had this problem?
https://www.sau.com.au/forums/topic/233941-help-water-leak/
#1 Dry the gaskets and seals arond the car
#2 If you have a spray puffer, put baby powder in it
#3 Express powder out of it against seals, door gaps etc
#4 Check and see where the white powder has penetrated
Cheers,
T
https://www.sau.com.au/forums/topic/233941-help-water-leak/#findComment-4101076
i also have a water leak ... when i use car wash and use teh high pressure hose... only on the drivers door ... were the glass sit up againts the rubber lining on the pillar ... it sprays thru .. nothing full on.. but u open the door and its like you have sprayed water from your mouth .... over the seat ... steering wheel .. dash ...cluster ... HEAD UNIT! .. door trim and runs down the pillar ...
anyone else had this ? or car to give it a shot .. in the end its only water ... :)
https://www.sau.com.au/forums/topic/233941-help-water-leak/#findComment-4105137
I'm getting loads of water in the drivers footwell!!! I've sealed up the grommet in the firewall and cleaned out the sunroof drains! But still it gets in!! Anyone have any ideas or have the same problem????
Any info would help guys!
Anyone know were the dual sunroof drains come out? Or have a diagram of them???
I have a similar one in my car but not as bad.. when i squirt my car with the high pressure hose i end up with water on the inside of the drivers and passenger windows..
https://www.sau.com.au/forums/topic/233941-help-water-leak/#findComment-4120426
