Hi all,
I recently got my c35 laurel and its 5 speed N/A neo 6.
I plan to do an engine swap within the next few months and was wondering if the pinouts for non-turbo neo 6's would be the same as the turbo ones.
I would imagine they would be since that is how it is with the r32 and r33.
Here is a pic of my harness and ecu if that helps. and also a few pics of the car in question.
https://www.sau.com.au/forums/topic/233967-neo-6-wiring-harness/
Thanks 666Dan. That makes things a little easier, I planned on rewiring the fuel pump anyway. I plan on putting an r33 rb25det into it around the beginning of next year, and plan on using the c35 harness and changing out most of the plugs. The thing is I can only find a pinout for the turbo ecu. Has anyone else swapped an r33 engine into an r34 or c35? any input would be appreciated, but if not i think i should be able to figure it out.
1400r, nice man. where are you from? I've seen a few c35's with sr's here for sale in the magazines, but they are expensive! How does it handle with an sr?
Edited by okidori
  • 3 weeks later...
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
