Hi all,
I recently got my c35 laurel and its 5 speed N/A neo 6.
I plan to do an engine swap within the next few months and was wondering if the pinouts for non-turbo neo 6's would be the same as the turbo ones.
I would imagine they would be since that is how it is with the r32 and r33.
Here is a pic of my harness and ecu if that helps. and also a few pics of the car in question.
https://www.sau.com.au/forums/topic/233967-neo-6-wiring-harness/
Thanks 666Dan. That makes things a little easier, I planned on rewiring the fuel pump anyway. I plan on putting an r33 rb25det into it around the beginning of next year, and plan on using the c35 harness and changing out most of the plugs. The thing is I can only find a pinout for the turbo ecu. Has anyone else swapped an r33 engine into an r34 or c35? any input would be appreciated, but if not i think i should be able to figure it out.
1400r, nice man. where are you from? I've seen a few c35's with sr's here for sale in the magazines, but they are expensive! How does it handle with an sr?
Edited by okidori
  • 3 weeks later...
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
