Make: Nissan
Model: 1995 Skyline GTS-T Series 1.5
Milage: 117000
Transmission: Manual
Colour: Electric Blue with Custom Pearl
Complied? Yes
RWC supplied? Negotiable
Currently registered? Yes
Price:Asking: $16,000 ... THIS IS AN ABSOLUTE BARGAIN
Contact: 0412 860 495
Comments / Modifications:
LOTS of modifications. LOTS of $$$ spent.
I'm the first owner in Australia and I've only managed 12,000 kms in the 18 months that i've owned it.
There is nothing wrong with the car, I'm selling it because I'm moving and there is no place for it at my new residence.
ENGINE: (Series 2 Motor) 117,000kms on the clock
-HKS 2540 Low Mounted Turbo With Custom Heat Shield
-HKS Intercooler Kit
-HKS Mushroom Pod FIlter (Stock Airbox with PiperCross Filter Included)
-Carbon Fibre Heat Shield
-Nismo 550cc Injectors
-Z32 AFM
-GReddy Oil Filter Relocation Kit
-Greddy HUGE Oil Cooler
-Nismo Fuel Pressure Regulator
-Blitz SBC-II Electronic Boost Controller
-Cusco High Pressue Radiator Cap
-Nismo Oil Cap
-Custom Blue Rocker Cover (Same Colour as Car)
-HKS Style Dump Pipe
-3inch Front Pipe
-JUN 3inch CAT + CAT-Back Exhaust (Sounds Fantastic) - Silencer will be sold with the car.
-Currently, Stock BOV is installed but have a GReddy Type S BOV that will be included.
MADE: 248RWKW on 16.5 PSI (Have dyno sheets to prove)
EXTERIOR:
-Custom Blue Respray with Heavy Pearl (Car looks purple under street lights)
-Full Bodykit
-Parker light covers will be included with the car
-Lipped Guards (front and back)
-Spoiler Removed and Bootlid Shaved.
WHEELS:
-Work S2R 18x8 at the front, 18x9 at the rear.
-Falken ZE329 235/40/R18 tyres stretched across the front.
-Bridgestone RE050A 245/45/R18 tyres stretched across the rear.
INTERIOR:
-Recaro Driver's Seat on Super Low Rails
-Momo Steering Wheel - Stock Steering Wheel with Airbag will come with the car
-Center Console Painted in the same Colour as the Car
-4 Defi StepMaster White Faced Guages with Controller (Oil Pressure, Oil Temp, Water Temp, RPM) - Up to 10 minutes record and playback.
-Autometer Silver SportsComp Monster Tacho with Blue Shift Light - Amber shift light will also be included with the car.
-Apexi Multichecker ECU Interface
-Blitz Turbo Timer - Have Carbon Fibre Looking DIN pocket that can house Turbo Timer and Boost Controller that will be included with the car.
-Pioneer DEH-P59501B CD/MP3/WMA Head Deck
-JBL 6.5 Inch Splits with Tweeters up front
-JBL 6x9s up back (CLEAN CRISP SOUND)
-Sony iPod Drawer mounted in one of the DIN pockets.
-Dash lights changed to blue
-Razo Gear Knob
-White Leather Gear Boot and Handbrake Boot
-Full Keyless Entry Alarm System
-Custom High-Mounted Brake Light
BRAKES / DRIVELINE / SUSPENSION
-HKS Coilovers (Height and Damper Adjustable) - Near New (No Leaks)
-HKS Twin Plate Clutch
-Tein Adjustable Castor Rods
-Nismo Mechanical 2-Way Diff
-Polyurethane Rear Subframe Bushes (Pineapples)
-High Temp Race Pads
-25mm Bolt-On Spacers
I'm sure there will be some things that I've forgotten.
There are a few issues with the car:
-Interior light and shift light are not hooked up to the tacho
-No interior globes
-Starter motor sometimes squeals when cold
-Front bar is busted and would need to be replaced
-Driver's door guide needs to be re-greased as opening it can be noisey
-No reap wiper
-Climate control motor sometimes knocks for 2-3 seconds on startup
Apart from these small things the car is perfect.
Edited by Syxti9
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
