How to go from the Penthouse to the cellar in one easy leasson. Power cruise at qr today Just doing what the natives do. Cruising, racing and having fun. During the off street racing segment I stopped on the back straight. Gave it 5 kay on the tacho and slipped the clutch to warm up the mickey T's in preperation for a race. What happenned next i wouldnt wish on anybody.
An incredibly loud explosion shook the shit out of the car, I clutched it and stopped it as quickly as I could and looked back to see a pile of debris scattered all over the track. The clutch housing literally exploded, the bellhousing was blown to smithereens, the slave was sent to god and probably still hasnt landed, shrapnell took out the dump which, fortunately saved the chassis rail. Bits of the back of the engine block were blown off. The starter motor copped it.
The majority of the blast fortunately went downwards in to the bitumen, fortunate for me because if it went the opposite way i shudder to think what may have happenned.
The clutch was a Jim Berry full monty, Pupportedly capable of holding some major horsepower. Wether I am just the unlucky one or not I dont know but I will not use another clutch without a burstproof housing and a kevlar blanket.
A very sobering experience.
Edited by FineLine
  • Replies 84
well I guess you've joined ben's club, glad to hear you weren't injured because that sort of accident could cost you your legs :thumbsup:
most likely it was the flywheel that went not the clutch - what flywheel was it?
I originally had a standard flywheel in the race car but we found hairline cracks - I changed it for a billet one for exactly this reason
well I guess you've joined ben's club, glad to hear you weren't injured because that sort of accident could cost you your legs :)
The os giken flywheel is still intact and bolted to the back of the engine. Its was the clutch housing that let go.
Edited by FineLine
Shit! I spoke to Jim about this when ordering my single plate clutch. He told me that the standard flywheel would be fine but i think ill change to a steel item next time i pull the gearbox.
Looking forward to pics of the clutch housing.
Think more about your clutch cover than your flywheel Shawn. Having done some preliminary homework already it would appear this is not an isolated incident.
I have already sourced a similar hp rated clutch with an antiburst cover for a lot less bucks than the berry. He can shove his full monty where the sun dont shine.
shite, sorry to hear. i wont get into it here because ive said it so many times, but these types of failures are the reasons i like to stick to decent stuff like ORC etc....
It would be interesting to hear what Jim says about this incident.
I actually bought a Nismo clutch and he modified it to suit my application, so hopefully i dont suffer the same fate.
Im really sorry to hear about this though. Ive sufferred engine failures due to things that werent my fault and it sucks.
Sorry to go off topic but you needed a nismo clutch modified? WHY MAN? They are among the best clutches, dont rattle, atleas mine didnt and feel prety much stock...
Well, maybe i shouldnt have said 'modified'. I bought a single plate nismo clutch that had worn out, sent it to Jim, and it came back all new and shiney. He increased the clamping force i know that, but as for the rest of it, im not sure. It certainly doesnt feel like standard pedal pressure though!
fk mate. i'm sorry to hear that. clutch or flywheel explosions are a very scary thing. one happend recently to a friend of mine and he was very lucky. some pieces of shrapnel pierced the floor and through the car roof. all he got was a cut thumb! (this one was an alfa race car and not using a JB clutch).
I can name a few such explosions now in skylines and all the ones I know of were running jim berry clutches. I don't know if it's coincidence or not but it is a worry. benm can tell you his story which for all intents and purposes made his car a financial write off. There was another also in sydney a few months prior.
Well I spoke (and spoke, and spoke, and spoke, and spoke, and spoke, and spoke, and spoke, and spoke) to Mr. Berry this afternoon and he expressed interest in pursuing the matter via his insurance company. Something to do with A dodgy batch of covers or such.
I've been jumped through hoops before so I dont hold much hope but I will pursue it regardless.
Will keep you posted.
god i didn;t think it was going ot be that bad from the description but then again pictures do paint a better image of what you were describing.
the flywheels looks intact wonder what sheered off
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
    • I think you might have skipped a whole vowel sounds there C.
