Ran a Lakewood scattershield on one of my high reving manual small block chevs a few years ago. They dont go over the bell housing they ARE the bell housing. Made of about 4-5mm pressed steel plate and theres a simmilar flat engine plate that goes up against the block. When or if a flywheel/clutch lets go it sort of holds it in place. A very good investment on hard turning engines.
  • Replies 84
So JB knows he had a bad batch of plates, but hasnt contacted his customers who's clutches came from the bad batch to warn them? Can anyone confirm if this is the situation or not?
If its true, i consider it irresponsible and unethical, considering the potential to loose limbs.
Noel,
Ive always had good experience with Direct Clutch in brisbane. For the rb30 im building i dont know if ill go a nismo/orc or go back and speak to Direct.
Tough choice, the clutch of theirs i have now has copped it hard for over 5 years and is still going strong. Was also strong enought to wear out the rb20 box
cheers, mic
Edited by Gts30t
Well heres the damge bill from that nano second of shit and disaster
Gearbox...chopped
clutch pressure plate andflywheel....Chopped
Engine.....chopped due to a chunk being blasted from the back of the block
dump.....choppped
starter motor.....chopped
clutch slave......chopped
bellhousing spacer plate....chopped
Braided clutch line....chopped
turbo water line.....chopped
Tore down the engine on the weekend so we can get the crank and jun pump xrayed. I dont anticipate any props but i am not taking any chances.
Now the madness begins all over again.
Oh happy Days! :)
Edited by FineLine
Gearbox...chopped
dump.....choppped
Oh happy Days! :(
not good to hear at all mate... that box is here if you need it
Some facts...The 3 clutches that have exited for differing reasons....one was a fractured flywheel one was a pressure plate and one was a clutch cover.
The flywheel one was a STD flywheel that had been fractured long before a Jim Berry clutch was fitted.
The other two im unable to give an accurate comment on.
For the record i no longer use Jim Berry clutches but would recommend that if anyone use them that they have the flywheel and pressure plate X-rayed before sending it to Jim. That way you can be confident that the product you recieve back will be up to the task and give both yourself and Jim piece of mind that your not sending him inferior materials to begin with.
Glad no injuries were sustained in this incident.
  • 3 months later...
Holy Crap! You are really lucky it was just the cover and not the flywheel aswell! Almost looks as if the cover was out of balance and threw its self apart.
Really sorry to hear about it, and not good news for a clutch builder either!
good one ray - see what you did now!
sorry, i got a bad habit of doing that. i just stuble across threads like these while searching and its amazing how many of them never have a posted conclusion.
I'd be interested to know too.. i have a JB sitting in the shed waiting for me to put it in......................
How much horsepower was involved in this???
Jim's clutches are second to none, 99% of these failures are because of external reasons and not fault of the clutch.
Be sure to
1: use proper nissan genuine clutch and flywheel bolts and washers
2: use the correct amount of dowel locating pins on the pressure plate
3: make sure your clutch & flywheel is crack free (x raying is the way to go)
4: if possible use a billet steel crome molley flywheel (ask jim to supply)
i cant remember what else but this will give you an idea. they are rated to high horse power applications, anthony martook uses them in his drag cars
Approx 480hp at wheels
Be sure to
1: Done
2: Done
3: You'd have to ask Jim about that as HE supplied the clutch and it was a standard SECO cover that he modified.
4: Done
You can be absolutely certain the clutch in Anthony's car is not the same as this one.
I'd just like to touch back on point 3. The SECO cover he used has a pressure plate made of cast iron. Every pressure plate made after the mid to late 90's is made from a Ductile cast iron.
Xraying it will tell you this but you would assume he doesn't use inferior parts that were practically banned from this type of clutch for this very reason. Cast iron is riddled with cracks. It's in the nature of casting it. He uses second hand normal cast iron pressure plates in all of the full monty's he makes. They are ALL ticking time bombs.
1: Done
2: Done
4: Done
Id like you to touch back on point 2 please.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
