Standard: 2.9/3.1 165/175
Tein: 3.1/3.8 6.8% 22%
Nismo: 3.8/4.4 31% 42%
they are the rates, you can get teins from access autoworks on here, i trust them, have been to there store, no probs.
or nismo's from nengun or RHDjapan.
the whiteline group buy springs on here are just
34gtr front
32gtr rear
Standard: 2.9/3.1kg/mm 165/175lbs/ft??
Tein: 3.1/3.8kg/mm 6.8% 22%
Nismo: 3.8/4.4kg/mm 31% 42%
34gtr front
32gtr rear
corrected, that is for a s1 rs4
hey mate cheers for the reply, but what exactly do those ratios mean?
Those are the spring rates, listed in kilograms per milllimetre and pounds per inch of travel
Example: the standard front springs need 2.9kgs of downward force to be moved 1mm (or 165lbs of force to be moved 1in).
Are the rear spring different for an RS4S? I remeber reading somewhere that they are different to the standard auto stagea.
Thanks
That's right, the RS4S has an R33 GT-R subframe for the rear suspension, and the way the shocks attach to the suspension at the bottom is different between auto and manual Stageas.
Also, RWD-only Stageas have different front suspension because (obviously) they don't need to account for a driveshaft going through the centre of the suspension and wheel hub.
with extra circlip grooves machined on your shocks you can get your stagea as low as you could ever want with the standard springs.
the spring rates on the RS4S seem to be decent as it is according to my bum-o-meter.
if you are buying whiteline springs just specify it is for a stagea.
Thanks, so just to confirm, To lower my RS4S I will need to order R33 GTR springs?
I have been reading up heaps on the suspension thread but there isnt much info on the RS4S
Cheers
Dave
i know theres a fair bit to read in the suspension thread but you maybe should have another look it's been covered to death, sedan springs going on a wagon is a much discussed topic, a bit of advice check out sk's suspension thread throughly....... everything you want to know.... goodluck.
Thanks,
All I am interested in is lowering it a little and want to keep that stock shocks, I have already spend a small fortune on the motor and dont race the car I just wanted it to sit a little lower to clean up the look.
Thanks
Dave
i know the exact feeling.
unfortunately we found the left front shock was leaking so the cheapest option in the long run was to replace the shocks but then we found there was no where near enough camber adjustment on the rear even with an aftermarket eccentric bush. with upper rear camber arms there is enough adjustment to get sensible rear camber settings. so one thing always leads to another...
ps. the rear of the stagea is at 365mm
    • Ok I FINALLY found a video lol. This took way longer than it should have as I could have sworn I saw multiple videos like this. I kept finding the completely opposite (the correct way of doing this). I wouldn't be surprised if I f**ked this up somehow.  I just realised where I've been getting confused and even with other things I work on. I haven't been doing things the regular way instead I'm going a roundabout way of doing things, like putting epoxy primer first then filler for example instead of putting just filler then primer on top of that, then wondering what happens if I get that primer on the clear coat that I haven't sanded yet. This was a bit of an epiphany 馃槀  But anyways, here this video. Time stamp, 2:56, some of the primer lands on the paint unscuffed above. You can see from the reflection it looks shiny.
    • It does, this part circled in red. I assume the OEM bolt might not work well with the poly bushing because the dimensions may be different?
    • The J arm doesn't have bushes either. Assuming that by "J arm" you mean the part of the upright that runs down from the upper arm's outer bushes to the top of the hub. That has a kingpin style bearing in it. If you meant the lower control arm, it has 1 bush, at its inner end. If you have PU in there, that is superior to Nismo rubber. If you meant the caster/tension rod - it has 1x bush at the front end, and again PU is superior to Nismo rubber. But as I said above, I would definitely get the GKTech arms for that, as sphericals slay all other options there.
    • Yep I'll find those and get back to you. To be honest I wasn't aware of data sheets until you mentioned it. I'm still new to this haha, lots to learn. My car is parked outside, it rusted in less than 24 hours lol. Only minor surface rust that was easily removed but I've been worried that it might rust from the inside out and screw me over in the long term (if I decide to keep the shitbox for that long).
    • Sorry I meant nismo bushes in the J arm, not the actual gktech upper camber control arm.
