So after my S14 RB25 maxing out a Q45 then Z32 i eventualy swapped the pfc to a R33 GTR D-jetro PFC,, that solved my problem,,,
My S13 has a MAF PFC as well and was maxing the Q45 at 1.3bar with the GT35... so i tried something a little different before ditching that for a D-jetro.
100mm intake with hacked Q45...
64mm center tube the sensor sits in to prevent turbulance that plauges these things
Finnished... well almost, still needs to be polished and to epoxy the sensor into place...
Now at 1.6bar im only at 4.6volts, should be able to get to my boost target now by 5volts, even better than this is that there is no usual part throttle surge or voltage movement which usualy happens.
Just a cheap upgrade option for those guys maxing MAF's
https://www.sau.com.au/forums/topic/234033-all-mafd-out/
Think about how a hot wire air flow meter works, it is only measuring the air going past the element itself, which is just a portion of the total airflow. This would just make it a different percentage, may not be perfectly linear response but should be able to be mapped against.
https://www.sau.com.au/forums/topic/234033-all-mafd-out/#findComment-4101862
I don't see how the sensor can now accurately measure correct airflow? You are only measuring one small part of it.
just change the load scale to suit. as long as the flow through the AFM is CONSISTANT in its ratio with the air going around, there will be no problem. which, unless there is turbulance through the pipe, wont be a problem.
now, that internal pipe may protect against, or make the problem worse (only my opinion). very interested to see results.
https://www.sau.com.au/forums/topic/234033-all-mafd-out/#findComment-4102375
And you dont have to use a Q45 sensor, just do the sums, and any nissan AFM sensor can be used, just need to get the pipe size right to suit. Mine is a stock gtr sensor in a 4.75in internal diameter pipe, should be 5v at 500rwkw
Just so happens i have about 10 Q45's laying around from cars ive changed to D-jetro. :rolleyes:
It works perfectly, I have done it without a center pipe before and it always picked up a cruize hesitation and usualy a .2 to .3v movement @80 - 120kph in the afm voltage from the air hitting the filter (which you can realy feel in an SR20), i now have thin, clean and smooth line when I use the oscilloscope. The center tube runs the length of the lower outer section, which means i have roughly 100mm of tube before and after the sensor itself to help the air smooth out slightly to stop turbo and air filter interference.
All i did to get it going nice was to rescale the AFM (over 35% at higher flow rates), still need to do a full tune obviously to see full benefit due to the added boost I can now run.
Edited by Rezlo
https://www.sau.com.au/forums/topic/234033-all-mafd-out/#findComment-4102402
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
