hello everyone just need some turbo advice thinking of upgrading to this T3 Hybrid turbo specs 0.63 rear, 0.60 front housing, 61mm front wheel t3 hi flow turbo stage 3 wheel
how much power can i expect to make and also what rpm will this turbo spool up at
turbo is going to be fitted to rb25
thanks
Edited by rbgtst
https://www.sau.com.au/forums/topic/234057-rb25det-t3-hybrid-turbo/
is it one of the old turbos made by HYBRID or is it just an ebay "hybrid" t04? i used a HYBRID branded turbo on a R34 GTT awhile back and it worked ok (bit laggy but not too bad) made 280ish.
thanks
The easiest way to do this is to figure out how much power you want first, if you want 300+rwkw then that turbo wont be much good due to the .6 rear and the fact its probably bush bearing, if your aiming for 200-250 then it will probably will do the job, but so would a high flow which would cost you less in the long run due to the fact that it is a bolt on, no need for custom dumps or inlet.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
