innovative here also :rolleyes:
buy the xd16 standalone gauge kit it works great, it comes with the xd16 gauge and the lc1 wideband controller, can be datalogged which is a well needed feature
http://www.innovatemotorsports.com/products/xd16.php
Edited by unique1
plx
+1
Never had one fail, super easy to read day and night and is very compact,
Another very good one on the market is the AEM, im selling them around $100us cheaper than the innovate or PLX, sure there must be somone in Ausi selling them?
VEMS is also pretty good, not sure if you guys have VEMS agents there though, currently the AEM is slightly cheaper though.
what ECU are you using? innovate doesnt have auxilary outputs, so if you can put these to good use, maybe check out the site paulr33 mentioned
its got two..... and has full POWERFC support.
i use the LM1 for street tuning and in the race car and the LC1 for other things.
I use the LM1 connected directly to emanage or FC-datalogits for accurate wide band logging.
Good read, compares the innovate wideband with aem and plx etc.
http://tunertools.com/articles/FordMuscle.pdf
yeah the owner of that site is a legend, very knowledgeable and his pricing is pretty sharp.
my favorite page..... my shameless claim to fame :rolleyes:http://gizzmousa.com/knock-monitor.html
my plx has been going strong, plus they have alot of other gauges which you can link up in series so you're not limited to one gauge type just for afr's. you can have your boost, temps and pressures read in the same style gauges.
This isnt an area id be taking chances on over a few hundred $, esp if your going to be tuning with it. The innovative gear is proven many times over.
How about the innovative lm2 can this unit work with fc datalogit. as i just got mine from http://www.rx7.com/store/rx7/fdecu.html
they told me that the datalogit is on longer vehicle specific. they can work on any car. does anyone know it this is true. the wbo2 that paulr33 recommends is good for guy's that live in Australia. i think its a Australia base company.
is this right.
is this right. I'm using a powe fc ecu.
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
