hi guys im having a bit of trouble with my current brakes thinking about an early upgrade for the GTS-T.
Not really sure what to go for hoping you guys can help us out. I know there are alot of other factors that i need to take into account like wheel clearence for the brakes etc.
Main things im looking for are:
-Cost of brakes
-Cost of fittment
-Best suitible brakes for a gts-t
Thanks in advance guys!
https://www.sau.com.au/forums/topic/234204-new-brakes/
What is the purpose for the car?
There's brake thread in 'Braking and Suspension' section of this forum, do a search there there's plenty of information there that should answer your questions.
Cheers
Grant
https://www.sau.com.au/forums/topic/234204-new-brakes/#findComment-4104258
how much are we looking at price wise for fronts and rears and also installation??
$2k plus, you'd better off rebuild the calipers with new discs, pads and brake lines.
Brembo is marginally better (not much) than standard brakes.
Like i said on previous post, do a search there, loads of info there.
Cheers
Grant
https://www.sau.com.au/forums/topic/234204-new-brakes/#findComment-4104270
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
