  • Replies 50
BROOOOOOOO!!!!!!
No more missfires! ahaha
Bought a set of splitfies today, I was too psyched and impatient to wait for the weekend. (left work early and everything lol)
Thanks for the help.... I love you guys :cool:
Haha glad to see this thread is helping lots of people with missfire problems.
All you guys who have bout splitfires and fixed the missfire problem, are you running sparkplugs with a 0.8mm gap or the stock 1.1mm gap?
Glad to hear. Coils should last a long time. Now to save $500
Do you think its worth checking the injectors (pulling the injectors out and getting them cleaned, or even running injector cleaner through) before i spend an arm and a leg on the splitfires?
Up to you. I know that my missfire is electrical so getting splitfires will fix it. If your coilpacks are going ok then getting splitfires wont help much. U can usually feel if its because somethings dirty and cloged up like injectors or sparkplugs compared to when the coilpacks are not producing a strong enough spark. Maybe try cleaning the injectors first as its cheaper and cant hurt. Otherwise you could take it to a tuner and get their opinion of what they think is the problem.
Hope that helps :P
Well it depends when it all started happening. My car started doing it ever so mildly when I put my fmic on. Then it was missfiring horribly when I put my exhaust on.
So I knew that they were they were the problem, I just didn't know how to get rid of the missfiring until I read this thread.
In other words, if your car started missfiring for no reason at all, I would probably get it looked at. But if you placed a FMIC on or similar it's most likely the coil packs. Thats what happened to me.
I put on the fmic and it was fine, i put on a turbo back exhaust and it was alright, it wasnt misfirring but the car wasnt smooth, it would pull to about 6 grand and then pull much harder from 6 to redline. I then put on a avc-r and still the car wasnt misfirring. After a week or so ir just started happening randomly, and now it even does it on standard boost (when avc-r is turned off).
Edited by da spike
Yeah rb engines start misfiring when breathing mods are upgraded. Exhaust, intake - cooler. Increasing boost will cause it to misfire too. This is because the coilpacks are old and weak. You will need to get new coilpacks or gap spark plugs till you get some.
I "had" the misfiring problem. Not anymore since the 6 coil packs and coil pack harness arrived yesterday. Three of my coil packs are clicking badly like every 4 sec and then the car jerks aka misfire. I changed 3 of the coil packs (front the front of the engine, the 1-2-3 ones. I also dropped the new coil pack harness (my old one was like what a dog would chew on) and no more misfire. Car runs smooth now. The initial problem was that my car only misfire at idle. I also have a FMIC Installed. Everything is stock atm.
Btw i got the used coilpack and harness from Raw Brokerage. Great service and the price was cheap (compared from my local wreck shop)
http://shop.rawbrokerage.com/category.sc?categoryId=35
Edited by teng
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
