I have some parts here that need to go. I can freight to anywhere at your expense. All parts are located in Hoppers Crossing, Victoria and pickup is more than welcome!
This is my own personal stuff - Do NOT send me Pm's requesting other Jap parts - We don't sell Jap parts!
Let's get started:
Pre loved 25mm 5x114.3 wheel spacers (pair) - $60 ono
- 3 broken studs (I'm told they can be replaced individually?
Pre loved 20mm 5x114.3 wheel spacers (pair) - $100 ono
- Pre loved in good condition
GENUINE Trust R32 GTR side skirts - $250ono
- Pre loved but in good condition
- Was used on my R32 GTR but removed as I prefer the standard look
- 100% genuine and perfect fit :huh:
R32 GTR passenger seat - $220ono
- good upgrade for S13/180sx's and R32's.
PICS TO COME SHORTLY
95 model 180sx shell - as is condition - $800ono
- 1995 model, original manual
- Complied but not registered
- Chassis rail has a small kink, doesn't look like much damage.
- Would suit a project car
9d1b51d8.jpg 7bf1f291.jpg 0f1df5d0.jpg f11edaf9.jpg 205ffdb8.jpg c2e695a5.jpg 97bfd640.jpg
R32 GTR plastic fuel tank - Perfect upgrade for GTS/GTST - $150ono (prefer pickup as it is quite large)
- Replace that heavy metal tank with the GTR plastic item
- Believed to have an extra 5liters or so of fuel capacity?
Complete GTR rear end - $1,000ono
- Includes subframe, diff, drive shafts, uprights etc. (complete minus brakes)
A31 cross member - $220ono
- Great to use in RB conversions on S13/180's
Brand new 180sx Z pillars - $200 ono
- Make your 180 look different to all the others
- Very rare item!
Tomei RB26DETT oil pan baffle kit - $270 FIRM
- Brand new in the packet (took out for a few pics)
R32 GTR RB26DETT Gizmo Thermal Intake Gasket - $100ono
- 100% brand new in the packet (took out for pics)
BNR34 GTR RB26DETT Jun Exhaust Cam shaft - $300ono
- 268 degree lift - 9.7 lift ???
Items are going quickly and first in best dressed!
I can be contacted at work on 1800 458 324
Greg
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
