  • Replies 143
Posted Images
some ive taken over the weekend whilst at powercruise.
i have something like 600 plus pictures from the 3 days, (( almost half of them of drifting / burnouts etc )) lots of imports.
but i wont bore you all with them, still gotta edit, delete etc etc, and have almost 2 hours of video to download from cameras hard drive and edit aswell.
sorry about bad pics though :)
picture of my 34, my brothers S2 33 ( the one with trial side front bumper) and my mate jims 33 ( s2 bumper)
My brother and me rolling slowly around the corner ready to drag to see whose is faster (( only problem with the cruise sessions is you get half way across a striaght and have to hit the brakes and roll slowly round the corner as the v8 boys dont like going fat round them ) i racked up 19km around the track in a session and my GPS said top speed of 175kmh, but average speed was 44km. so hmm
This idiot entered the drift event, but all he did was do a burnout, sadly for him, halfway through the corner ( directly opposite our campsite) his wheel came off, yet he kept with the one wheel burnout for a while, then was towed onto the grass lol
two r34 gtrs
this guy was really impressive, have lots of photos and vid ill upload later , he got quite impressive by the end of the weekend. i have him coming off and loosing the bumper on cam,
anywya that it for me, sorry about the bad quality and if they suck :D
Edited by Silver_R34_GT-T
they say equip in the middle, starcorps? and i think they look good :wub:
all good. work equips are the original wheels that starcorp copied. you see starcorps on a LOT of imports. equip = respect
gus those are some really good shots. i have seen a few pics from under that bridge though. lol
yeah i think everyone has taken photos at that bridge...my favorite are the ones of the national library and the national museum (the other two) but the bridge is just a really good spot to play around with the settings and get some good variation....also good way to practice you composure.
i'll try for some variation next time, find some spots no one knows of haha
oi! he's not an idiot - he's a friend of mine and he's pretty good!
at the Stadium Drift finals (held in May or something) he got 4th place in the single runs and his team won the tandems
some nice pics btw :wub:
@GUS: whats with the random resolutions? you crop each of them a different size individually?
didnt starcorp copy the IMPUL's hence they call them starcorp impuls?
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 馃槕. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
