yeah i wouldn't mind a program i can download to edit, atm im using photobucket and i dont like it :D
nothing beats trying to overlay two photos with film...has anyone tryed to do that before??
in photography class that was my favorite, trying to put cool clouyds from one photo into another bland photo....never seemed to work but was hard
  • Replies 143
Posted Images
photobucket to edit photos??
you gotta get yourself a real program lol
There are some freeware tools out there that can edit photos (even if its simple program to increase contrast, brightness etc)
Gus if your lens cant focus automatically set it to manual and focus that way
It looks like xmetal has a 50mm f 1.8 lens.
your stock kit lens (18-55mm) can not go wide open at 1.8 and say 50mm - which is what he has done in pic 2.
I would suggest you get yourself a 50mm f.18 lens :P
Great for low light work and does great bokeh work :)
Check out my pic in page 3 :)
yeah what i'm asking is how did he get the background blurry etc....and i jsut realised a stuffed up by saying close up the aperture haha.
what i should have said is "did you just open the aperture up" and he would have said "yes" ...
my bad....
quick question....your iris for the aperture, that is in the lens or the camera shell? as in can you buy a lens with a wider aperture? i'm guessing by what u jsut said you can...but just checking
Its the lens.
The 50mm f1.8 lens is great for bohek (blur)
"Bokeh (derived from Japanese bokeaji ボケ味, "blur") is a photographic term referring to the appearance of out-of-focus areas in an image produced by a camera lens using a shallow depth of field.[1] Different lens bokeh produces different aesthetic qualities in out-of-focus backgrounds, which are often used to reduce distractions and emphasize the primary subject."
hope this helps!!
The 50mm f.18 is only 120 bucks brand new :P
some interesting photos in here
the spraybottles look good xmetal, they both look a little grainy to me, did you sharpen them a bit?
so whats in everyone's kits?
oh and is it only me, or does anyone else hate the bokeh term.......dont ask me why..
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
