Wish the stars were a little m ore visible, would be hard with the amount of lights in the shot though; stunning shots anyway Pie :D Did you use the photobucket tool to border them?
yeh it was a dead still night last night but just couldnt get it sharp enough to bring them out.. plus wasnt many stars out :P
nah I use Infranview for boarders and size, also to change colours and add effects... I cant get my head around photoshop atm o its an easier program to use for simple stuff :)
will be heading out again as I wanna try some new things :)
  • Replies 143
Posted Images
Received my 50mm lens today..
Some quick test shots.. auto mode hand held..
Shitty weather outside so cant really go out and take photos.. Will post up more photos when i get the time next!!
But im loving this lens so far.. Sharp, light and the colours come out great..
Edited by Sl!m
sid lovely shots.
Gus, your getting good man! i need to pop up to canberra and get some new shots of my car, need you to show me around champ :banana:
Bags riding shotgun. :D
Gus: Are you using a tripod? Maybe it's time to invest in a cable shutter release so you don't get camera shake with your night shots. Cheaper alternative to forking out big cash for a top shelf tripod. :)
i feel sorry for the chaser guy cos i love that car!! lol
yeh its cool - he had it fixed the next day
mine from last night
wow last 2 are awesome goodwork
siddr20 and Xmetal - awesome
some i took at nerdfest in sydney (all a bit average im afraid)
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
