  • Replies 143
Posted Images
almost looks like you've done a partial desat on that silvia. i likey
slim i like that blue s13 pic :/
slim the boost gauge shot is fantastic!
Cheers guys :D
I think I need to give the boost gauge shot another go with the car turned off this time though to get rid of the blur
First time trying some HDR photography...
Any tips would be appreciated :D
Awesome shots mate, would love to get in to some HDR photography myself.
Bags riding shotgun. :/
Gus: Are you using a tripod? Maybe it's time to invest in a cable shutter release so you don't get camera shake with your night shots. Cheaper alternative to forking out big cash for a top shelf tripod. :D
well i usually use a tripod at night. but when u drive half an hour to the city, and realise you forgot the tripod you kinda don't feel like driving back jsut to get it.
solution, drive the your local canberra centre right up the doors where theres a million lights, tell the security guard your jsut getting some photos for a magazine n your all sweet. then watch everyone turn their head as they drive past wondering how the hell you got up there.
i can't see us using that spot again. we went to the national museum once, if anyne has seen it it's got al these cool orange lights n stuff which we decided to drive 3 cars up into, (front doors basically) turns out mr security wasn't to happy)
canberra is a bit of an annoying place to try find good spots that people haven't been to before. sucks big time.
Jack88's R33.
This one below is massively edited...1) because it was so dark in the first place that it looked pretty shit in the first place. Thats cos i was mucking around with settings trying to get the aperture and shutter speed right. and 2) just for some fun haha.
I don't know if it 'works' or not.
And a couple of the view:
some from my backyard n stuff today
i was bored :D
i like the two wheel barrow ones, the one of my feet was just taking pics stumbling around on this wodden thing we have i reckon it's kinda cool, pool ball was working on depth of field and the ground for some reason just holds my attention for so long
Edited by Gus-
Any tips would be appreciated :(
Great work there.
Can you tell us how you acheived this HDR.
That is the PP after merging few photos. As in tone mapping etc..
ta
High Dynamic Range, where you take 3 pics of the same thing at low, normal, and high exposure and then blend them into one image.
Or if you want to get really messy you can take 2 under, 1 normal and 2 over but that's getting a bit out there. :( :(
Great work there.
ta
Thanks :dry:
I took 3 photos (underexposed, normal, overexposed), and used an app called photomatix to merge them together. I could never get HDR's to work in Photoshop, but it's pretty easy with photomatix.
Thanks :D
Ah you used photomatrix. Yea i can never do it properly in Photoshop either!!
Is photomatrix free?
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
