yeah i wouldn't mind a program i can download to edit, atm im using photobucket and i dont like it :D
nothing beats trying to overlay two photos with film...has anyone tryed to do that before??
in photography class that was my favorite, trying to put cool clouyds from one photo into another bland photo....never seemed to work but was hard
  • Replies 143
Posted Images
photobucket to edit photos??
you gotta get yourself a real program lol
There are some freeware tools out there that can edit photos (even if its simple program to increase contrast, brightness etc)
Gus if your lens cant focus automatically set it to manual and focus that way
It looks like xmetal has a 50mm f 1.8 lens.
your stock kit lens (18-55mm) can not go wide open at 1.8 and say 50mm - which is what he has done in pic 2.
I would suggest you get yourself a 50mm f.18 lens :P
Great for low light work and does great bokeh work :)
Check out my pic in page 3 :)
yeah what i'm asking is how did he get the background blurry etc....and i jsut realised a stuffed up by saying close up the aperture haha.
what i should have said is "did you just open the aperture up" and he would have said "yes" ...
my bad....
quick question....your iris for the aperture, that is in the lens or the camera shell? as in can you buy a lens with a wider aperture? i'm guessing by what u jsut said you can...but just checking
Its the lens.
The 50mm f1.8 lens is great for bohek (blur)
"Bokeh (derived from Japanese bokeaji ボケ味, "blur") is a photographic term referring to the appearance of out-of-focus areas in an image produced by a camera lens using a shallow depth of field.[1] Different lens bokeh produces different aesthetic qualities in out-of-focus backgrounds, which are often used to reduce distractions and emphasize the primary subject."
hope this helps!!
The 50mm f.18 is only 120 bucks brand new :P
some interesting photos in here
the spraybottles look good xmetal, they both look a little grainy to me, did you sharpen them a bit?
so whats in everyone's kits?
oh and is it only me, or does anyone else hate the bokeh term.......dont ask me why..
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
