I bought one of those underdash neons for my r32 that come with cigarette lighter plug but i want to connect them to car's 12V accessory power supply instead of having them plugged into lighter all the time.
They have a black wire (+12V) and black wire with white stripes (GND). I neved did any electric installations on my r32 before so I'd appreciate some tips... I want to connect them to accessory wire and I dont know which one is it and where do I put GND wire? Should I just cut acc wire and solder black wire onto it?
thanks heaps :(
https://www.sau.com.au/forums/topic/234299-connecting-underdash-neons/
you can get a switch and place it in the car as i did with my old car.
just get the positive wire and a ground wire and solder it to the switch and get the positive and negative from the neon and solder it to the correct place on the switch and place the switch where ever ya want.
Easiest way is to solder the wires off the cigerette lighter.
The cig lighter has a ring which lights up when you turn on the lights.
Cig light also has ground.
Pull off the plastic stereo shroud so u have access to the back of the lighter. Pull off the cig lighter wire clip and test with a multi-meter which one is ground and which one is power etc
There is a two-wire plug (+ve & earth) for the lighter and a single wire for the light in the socket.
It's important to be careful removing these wires as the single-pin one for the light is fragile and may break.
More info here http://www.skylinesaustralia.com/forums/R3...em-t204874.html
can you be cheap and not solder the wires together but just wrap it together and cover it with electrical tape?
i ask because i don't have a soldering iron and the only experience i have with soldering is year 10 electronics but didnt seem too hard
Thanks. :banana: Where behind the cigarette plug do I solder though? Just on the casing itself or on the wires?
Cant remember what i did, but you can do something similar to this;
http://blog.hemmings.com/index.php/2007/11...h-splice-wires/
i actually did something similar with my gps unit... i was sick of having cords/cables n shit all ova my dash so what i did was headed down 2 super cheap :( n bought a cigarette lighter extension lead for like $12. i cut it in half and joined it behind the original cigarette lighter socket. you should be able to easily identify the + and - wiring. black SHOULD always be the return part of the circuit (-). all i did was strip the feed wires to the original cigarette holder with a knife, strip the ends of the new socket i bought, twisted the + to the + and the - to the -, soldered the joins and taped them up. very simple.
i will admit tho i am an electrician :( but seriously, u cant really stuff it up...
i had some neons in my old car. had to cut the lighter ends off and connect em all. i found the other easy spot to connect is on the back of the head unit.
i just hooked the neon positive up the the yellow constant cable off the head unit and earthed it in the same spot as i earthed the head unit.
then drilled a hole in the back of that plastic fill in section you buy wen you change from double din to single and screwed the switch in there. nice and hidden plus easily accesible!
gl
i'm wiring lighting for my boost gauge
for the positive i'm goin to use the light for the cigarette socket
and was wondering for the ground if i can use the earth on the actual cigarette heating part?
but was also thinking bout putting the earth under one of the nuts on the gearboot?
taks.
yes, easiest way to do earth, is to put it under a bolt that is connected to an unpainted part of the chassis.
as to the 'do i have to solder' thing. u can crimp them, but u still have to cut the wire, strip it and then crimp it up.
easiest way ive found...if u have the room is to get inline crimps. soooo much easier
all u do is slip it over the wires, and push down. and a piece of steel slices into the wires, creating a connection
i actually did something similar with my gps unit... i was sick of having cords/cables n shit all ova my dash so what i did was headed down 2 super cheap :D n bought a cigarette lighter extension lead for like $12. i cut it in half and joined it behind the original cigarette lighter socket. you should be able to easily identify the + and - wiring. black SHOULD always be the return part of the circuit (-). all i did was strip the feed wires to the original cigarette holder with a knife, strip the ends of the new socket i bought, twisted the + to the + and the - to the -, soldered the joins and taped them up. very simple.
Ive been thinking about the same idea;
buy one of these cig lighter extensions;
http://jaycar.com.au/productView.asp?ID=PP...=&SUBCATID=
Break up the connector, hardwire it behind the factory cig lighter and feed the new cig lighter into the glove box :)
Ok ive bought some neons aswell.
4 Neons in total.
Front - Drivers and Passengers footwell.
Back - Underneath Seats, for Passenger foot area.
Now all 4 neon's Positives will be soldered to one peice of wire which is going to be my positive. All 4 Neon's Negatives are going to be soldered to one peice of wire which will act as the negative.
Now i have 1 Positive and 1 Negative wire.
These are going to be soldered to the Positive and Negative terminal on the Switch.
To provide power to the switch, i will solder a peice of wire from the switch to the ACC wire on my Cig Lighter ( the light one )
To provide the negative, a peice of wire will be soldered from the switch to the ground/negative for the Car Lighter ( Light ).
Is this the right way to wire my neons ?
I just want to clarify this because i do not want to fry my electricals lol.
MRXTCZ
depends how you want them to work..
when i was in "night club in my car stage" in my VT.. i had three switches.. one for inside neons.. one for front washers/wipers.. one for front/underneath..
i hooked the +ve's to the switch (crimped and soldered to a female plug) which slips straight onto switch (or take off if wanted) .. i hooked the earth to a screw under the dash (or an earth wire head unit black wire, cig lighter) then i ran wire out of fuse box to a 15A fuse and then down to the switch.. that way any problems and the fuse blows hence this won't fry the electrics.. and i can turn power on and off to neons when i wished..
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
