hey guys just wondering what's more cost effective
Rebuilding the current rb25 or dropping an rb26 motor and box in there
Why? Because I can LOL , I know there's heaps of advantages with the rb26 + I'll get to have twins the only thing stopping me at the moment is what sort of labour hours it will take + my motor currently has the following mods
52mm radiator
Intercooler
PFC
Turbo back exhaust
The obvious pod and enclosure
+ I just got some gauges put in
I'm just not sure what will have to be sold off and what can stay to work perfect
The cooler will have to be changed the dump and front pipe as well
How about the radiator ?? Will the radiator hoses fit??
The PFC can make way for a gtr PFC or stock ecu for a while
The reasoning behind this is it'll cost 4k for a mild build to handle roughly 325rwkw while a gtr engine shouldn't need a build for that much should it? Plus I get solid lifters and the 6throttles and twins not to mention extra capacity
Anyhow calling everyone that's done this before to advise me on what has to be changed
https://www.sau.com.au/forums/topic/234300-rb26-engine-conversion/
Depending on the age/condition, the RB26 will need more than 4k thrown at it just like the 25.
Either way, the RB26 wont take 330rwkw forever. Few years probably but thats it
The extra capacity, is next to nothing, its not even a 100cc, about half that :(
A 26 conversion isnt cheap, and IMO you'd be crazy not to at least through new pistons/bearings etc through it before installing it
26 ain't cheap, to fix, parts etc.
Rebuild the 25= fresh engine, tough etc.
If you got the money though, go for it lol.
I agree with GTRsean. If you got the funds, go for the RB26.
But to be honest what is your target RWHP figure????
That will determine whether you even need to go RB26.
I have seen some strong RB25's doing 500RWHP all day every day................... :(
I have two GTR's. But that does not mean that I will push and promote RB26's........
RB25 is a very solid motor.................
Again, what is your target figure?????
rb20s are cheap and strong
That is true. RB20's are a fantastic motor.
However he already has a RB25. So why would he put an RB20 into his ride?????
It's a case (as he stated in his initial thread post) whether he should rebuild his Rb25 or outlay for a RB26 (Money Pit..............)
yeah target is 300rwkw to around 350rwkw umm it's just for a bit of fun really something to use at the odd track day, motorkhanas etc
Well combining my tax return and savings I've got 7k and I really would like to keep everything as hidden as possible from the eyes of the po po's so low mounts, I've forgot to mention it used to be a non turbo (turbo conversion) so I'm not even sure how much more it can take I've got 202rwkw at the moment oh I'm not doubting the rb25's they are awesome but I am doubting my de bottem end haha, I've had a chat with a few places and really they said just for 300rwkw there is a low mount that can support it + I can get a mild build with gtr rods + upgraded rod bolts and pistons that they have said should be enough for that power figure (and ofcourse a compression ratio of 9:1)
+ I'm not sure how much machining it will need
Anyway at the moment i'm just in the thinking stages
Cheers
i know my rb20 comment made me look stupid yet it wasnt seious, on a serious note however have you considered an rb30, still looks stock so popo dont notice, depending on the turbo can keep you current exhuast and intercooler, retune the power fc you have and keep your radiator, would take more money to get it to 8000 revs though, yet a 500cc increase you will notice more than just 100cc
I think with your budget ($7K) you don't have a choice but to go with the RB25 route.
By the time to buy a decent RB26/gearbox +Turbos and associated supporting hardware you will blow the $7K budget.
If you can save more you will not regret getting the RB26.
But as Nismoid said before, the Rb26 is really only 100cc's more. What the point of going RB26???????????
yeah I have considered it, I've also seen people just chuck the stock rb30 with upgraded bolts on make a reliable 270rwkw what do you guys think it's cheap will last 250rwkw and will leave me cash for other areas of the car
so we are looking at pistons, gtr rods upgraded rod bolts, acl bearings and new gaskets all round that only looks to be setting me back around 2k will I need to do any machining etc? After all it's not an all out build this way I can spend on other areas , maybe If I can keep it to 4k then I can spend 2k on the turbo and 1k tune up, but like I said before if I did the rb30 just with rod bolts and gaskets it'll only be like 1k then 1k bolting it up then 2-3k on new turbo and I'd have 2k to spend on other areas of the car, who's the guy that's done this before he just bolted a stock rb30 bottom end up to his rb25 bigger turbo and started drag racing?
I did the same thing I wanted to upgrade to a rb26 instead of the rb25 and it has cost me in the excess of $20k, this is what you should do if you go for the rb26..
Cost of engine $3000-$5500 (please make sure they supply comp test and op test & a warranty if possible)
Cost of head gasket from Nissan $80.00 this is so you can pull it down and inspect, there is nothing wrong with genuine head gaskets. This is where it cost me so much, engine was sold to me as a good runner but we pulled it down and found damage to the block and pistons so complete rebuild.
Rewire of wiring harness to run rb26 computer $200-$600 (depending on where you go)
Computer $300-$5500 (depending on where you go & what you use)
Modify intercooler plumbing $150-$500 again (depending on where you go)
Modification to sump $300-800 (depending on where you go)
If you want to make power at high rpm a good oil pump and coller is recomended, can go into the whole debate here but an N1 is a good start its supperior to a standard item to start with.
A good harmonic ballancer ATI or ROSS most profer ATI as do I.
Oil control, while modifing the sump ensure extra compacity and baffles maybe even a return from the back of the head to sump.
If you are staying with the twins make sure you change the dump pipes while the engine is out of the car likewise if changing the turbos. (its hard enough doing it when the engine is out let alone in the car)
Replace all heater/vacume/oil lines under intake plenum while engine is out too this is for peice of mind.
I think staying the the rb25 and upgrading the rob bolts to start with is a much wiser choice and will be cheaper in the end. I could keep going but hopefully this will be some help to you.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
