hey guys just wondering what's more cost effective
Rebuilding the current rb25 or dropping an rb26 motor and box in there
Why? Because I can LOL , I know there's heaps of advantages with the rb26 + I'll get to have twins the only thing stopping me at the moment is what sort of labour hours it will take + my motor currently has the following mods
52mm radiator
Intercooler
PFC
Turbo back exhaust
The obvious pod and enclosure
+ I just got some gauges put in
I'm just not sure what will have to be sold off and what can stay to work perfect
The cooler will have to be changed the dump and front pipe as well
How about the radiator ?? Will the radiator hoses fit??
The PFC can make way for a gtr PFC or stock ecu for a while
The reasoning behind this is it'll cost 4k for a mild build to handle roughly 325rwkw while a gtr engine shouldn't need a build for that much should it? Plus I get solid lifters and the 6throttles and twins not to mention extra capacity
Anyhow calling everyone that's done this before to advise me on what has to be changed
https://www.sau.com.au/forums/topic/234300-rb26-engine-conversion/
Depending on the age/condition, the RB26 will need more than 4k thrown at it just like the 25.
Either way, the RB26 wont take 330rwkw forever. Few years probably but thats it
The extra capacity, is next to nothing, its not even a 100cc, about half that :(
A 26 conversion isnt cheap, and IMO you'd be crazy not to at least through new pistons/bearings etc through it before installing it
26 ain't cheap, to fix, parts etc.
Rebuild the 25= fresh engine, tough etc.
If you got the money though, go for it lol.
I agree with GTRsean. If you got the funds, go for the RB26.
But to be honest what is your target RWHP figure????
That will determine whether you even need to go RB26.
I have seen some strong RB25's doing 500RWHP all day every day................... :(
I have two GTR's. But that does not mean that I will push and promote RB26's........
RB25 is a very solid motor.................
Again, what is your target figure?????
rb20s are cheap and strong
That is true. RB20's are a fantastic motor.
However he already has a RB25. So why would he put an RB20 into his ride?????
It's a case (as he stated in his initial thread post) whether he should rebuild his Rb25 or outlay for a RB26 (Money Pit..............)
yeah target is 300rwkw to around 350rwkw umm it's just for a bit of fun really something to use at the odd track day, motorkhanas etc
Well combining my tax return and savings I've got 7k and I really would like to keep everything as hidden as possible from the eyes of the po po's so low mounts, I've forgot to mention it used to be a non turbo (turbo conversion) so I'm not even sure how much more it can take I've got 202rwkw at the moment oh I'm not doubting the rb25's they are awesome but I am doubting my de bottem end haha, I've had a chat with a few places and really they said just for 300rwkw there is a low mount that can support it + I can get a mild build with gtr rods + upgraded rod bolts and pistons that they have said should be enough for that power figure (and ofcourse a compression ratio of 9:1)
+ I'm not sure how much machining it will need
Anyway at the moment i'm just in the thinking stages
Cheers
i know my rb20 comment made me look stupid yet it wasnt seious, on a serious note however have you considered an rb30, still looks stock so popo dont notice, depending on the turbo can keep you current exhuast and intercooler, retune the power fc you have and keep your radiator, would take more money to get it to 8000 revs though, yet a 500cc increase you will notice more than just 100cc
I think with your budget ($7K) you don't have a choice but to go with the RB25 route.
By the time to buy a decent RB26/gearbox +Turbos and associated supporting hardware you will blow the $7K budget.
If you can save more you will not regret getting the RB26.
But as Nismoid said before, the Rb26 is really only 100cc's more. What the point of going RB26???????????
yeah I have considered it, I've also seen people just chuck the stock rb30 with upgraded bolts on make a reliable 270rwkw what do you guys think it's cheap will last 250rwkw and will leave me cash for other areas of the car
so we are looking at pistons, gtr rods upgraded rod bolts, acl bearings and new gaskets all round that only looks to be setting me back around 2k will I need to do any machining etc? After all it's not an all out build this way I can spend on other areas , maybe If I can keep it to 4k then I can spend 2k on the turbo and 1k tune up, but like I said before if I did the rb30 just with rod bolts and gaskets it'll only be like 1k then 1k bolting it up then 2-3k on new turbo and I'd have 2k to spend on other areas of the car, who's the guy that's done this before he just bolted a stock rb30 bottom end up to his rb25 bigger turbo and started drag racing?
I did the same thing I wanted to upgrade to a rb26 instead of the rb25 and it has cost me in the excess of $20k, this is what you should do if you go for the rb26..
Cost of engine $3000-$5500 (please make sure they supply comp test and op test & a warranty if possible)
Cost of head gasket from Nissan $80.00 this is so you can pull it down and inspect, there is nothing wrong with genuine head gaskets. This is where it cost me so much, engine was sold to me as a good runner but we pulled it down and found damage to the block and pistons so complete rebuild.
Rewire of wiring harness to run rb26 computer $200-$600 (depending on where you go)
Computer $300-$5500 (depending on where you go & what you use)
Modify intercooler plumbing $150-$500 again (depending on where you go)
Modification to sump $300-800 (depending on where you go)
If you want to make power at high rpm a good oil pump and coller is recomended, can go into the whole debate here but an N1 is a good start its supperior to a standard item to start with.
A good harmonic ballancer ATI or ROSS most profer ATI as do I.
Oil control, while modifing the sump ensure extra compacity and baffles maybe even a return from the back of the head to sump.
If you are staying with the twins make sure you change the dump pipes while the engine is out of the car likewise if changing the turbos. (its hard enough doing it when the engine is out let alone in the car)
Replace all heater/vacume/oil lines under intake plenum while engine is out too this is for peice of mind.
I think staying the the rb25 and upgrading the rob bolts to start with is a much wiser choice and will be cheaper in the end. I could keep going but hopefully this will be some help to you.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
