R31Nismoid know where your coming from...
it cost me
$150 for shot peening
$150 for rod bolts
$170 for balancing & resizing
if I knew at the time that it would cost that much definately would have gone forged rods :P
I prepped my standard RB26 rods too; cost me about $600 or something like that about 2 years ago. Now you can buy forged rods for US$300. While my rods are fine, i would have rather spent $300 less for forged items! Have a look on ebay USA site.
I havent added it up because it ruins the enjoyment, but i must have spent over 20 grand on my rb26 conversion. Always figure out how much it'll cost, then triple it; even quadruple it!
I reckon the rb30 with 25 head would be interesting. Have a look at Cubes engine bay in the engine bay photos thread. It looks great.
lol sometimes it seems its much cheaper to buy an engine thats already been built off the forums here :P anyone had any experiences? would you do it? if you could save 6K? but then you dont know whats been done until it goes pop lol
it cost me
$150 for rod bolts
yeah fair point.
Although i wouldn't think they would need any shot work for this setting (i dont think mine did), suppose the usual balance etc, but then wouldnt A/M ones need the same?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
