Hey mate, did you get the plugs that come with the injectors?
are you after the plugs because the ones supplied don't fit as the two side tags on the injector hit on the plug?
I had the same problem when I got my Sard 800's, I just ended up shaving with the side tags off the injectors to fit, no dramas since... :wub:
but if any of that ^^^ does't apply and you dont have any plugs at all, http://www.efi.com.au/index.php Company that stocks the Sard plugs (exactly the same ones that come with the injectors from Sard, so have to shave off the side tags aswell) here is Brisbane, their dealers in S.A is:
Automotive Service Solutions SA
65A Grange Rd & Welland Ave
Welland SA 5007
Free Call 1300 30 35 40
Phone: (08) 8241 7555
Fax: (08) 8241 5541
Email: [email protected]
hope this helps :P
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
