is nice....
I'm not sure about in vic but there are a few perspex places in syd that can knock something up pretty easily. or you could consider the sard surge tanks which mount the pump inside the tank which is a good idea, and looks neat. plus being inside the tank surrounded by fuel it tends to quieten down the pump a bit. :D
edit: I seem to remember paul dirtgarage had a very nice perspex cover for his pumps and surge tank. pretty sure it's his set-up I'm picturing. had neat little holes with rubber grommets for the hoses to pass through.
Yeah, I think a custom one from a perspex manufacturer may be the go. I know there's on in Sunshine here in Vic, but I was just not sure when I'd get the time to go there to get it done. I should do it though as I need a second one made for something else.
The Sard setup is really nice, but I already have a surge tank, so I want to go with that. I just need to section it off from the cabin for CAMS approval.
I might shoot Paul a PM too, thanks Richard.
Yeah it was a Performance Metalcraft product...i think they no longer do them. The enclosure is required for all internal surge tanks that are not totally sealed from cabin to comply with ANDRA regulations. It prevents fuel from spraying around inside the car in the unfortunate circumstance of a hose or fitting failure or accident.
Looks the part too.
Edited by DiRTgarage
hey all as ive read some of u guys are in need of a surge tank enclosure if all goes well and i go ahead making it i would be happy to make more for others let me know
thanks Daniel
What sort of design are you looking at?
I'm coming up with a design at the moment Steve, and I'll work through it with Daniel. I basically want a rectangular unit that will fit into the spare wheel well, with a perspex removeable lid, like the one attached.
Hey lads just in case if you need another fabi I could prob help out (not trying to cut your lunch Dan just offering). It looks like a simple bit of kit should be pretty easy to make let me know.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
