is nice....
I'm not sure about in vic but there are a few perspex places in syd that can knock something up pretty easily. or you could consider the sard surge tanks which mount the pump inside the tank which is a good idea, and looks neat. plus being inside the tank surrounded by fuel it tends to quieten down the pump a bit. :D
edit: I seem to remember paul dirtgarage had a very nice perspex cover for his pumps and surge tank. pretty sure it's his set-up I'm picturing. had neat little holes with rubber grommets for the hoses to pass through.
Yeah, I think a custom one from a perspex manufacturer may be the go. I know there's on in Sunshine here in Vic, but I was just not sure when I'd get the time to go there to get it done. I should do it though as I need a second one made for something else.
The Sard setup is really nice, but I already have a surge tank, so I want to go with that. I just need to section it off from the cabin for CAMS approval.
I might shoot Paul a PM too, thanks Richard.
Yeah it was a Performance Metalcraft product...i think they no longer do them. The enclosure is required for all internal surge tanks that are not totally sealed from cabin to comply with ANDRA regulations. It prevents fuel from spraying around inside the car in the unfortunate circumstance of a hose or fitting failure or accident.
Looks the part too.
Edited by DiRTgarage
hey all as ive read some of u guys are in need of a surge tank enclosure if all goes well and i go ahead making it i would be happy to make more for others let me know
thanks Daniel
What sort of design are you looking at?
I'm coming up with a design at the moment Steve, and I'll work through it with Daniel. I basically want a rectangular unit that will fit into the spare wheel well, with a perspex removeable lid, like the one attached.
Hey lads just in case if you need another fabi I could prob help out (not trying to cut your lunch Dan just offering). It looks like a simple bit of kit should be pretty easy to make let me know.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
