I'm coming up with a design at the moment Steve, and I'll work through it with Daniel. I basically want a rectangular unit that will fit into the spare wheel well, with a perspex removeable lid, like the one attached.
sprinter boot isnt it?
mate made one for his brothers ae86 running the 1JZ - curved surge tank to match the wheel well and had the lines exiting the side of the well, then sealed up.
33 boots are not round like the pic above, they are more square and have a step in them that would make the use of a single sheet to cover it bulky.
get a torch out and lightly heat it so you can bend it.do it one more time to finish the step. worth a shot :)
Hey Chris, the example was a sprinter boot, and the champagne coloured boot is a 180SX boot, which is what I want to get the enclosure made for.
I have a small, square surge tank which is only about 150mm high so I could fit it into that area.
  • 2 months later...
hows this coming along?
i need a new little project to make up at work?
i just need to knwo what it consists of! lol
we just wanted to replicate the one in the first post. Just alloy sheet folded n stuff with a perspex cover. and a few fittings welded on so the fuel can get in and out and the smell stays in.
Chard on here was going to make me one, but due to issues at his work has taken too long so I'm looking at more sources now.
I'm speaking with Daniel (Activ32), but if you want to make it Blaq let me know.
This is what I'm after, but dimensions can change slightly if it would suit more people. Just an ally box with a perspex lid, pretty simple.
So whoever want to do it let us know! Car is nearing completion and I want as soon as I can get it done for a reasonable price.
Just measured that up in my boot and that box is huge, i will most likely want only want a 300 deep, 450-500 wide, (what ever height a std surge tank is ??? 400-450),
with 3x jic male to male fittings welded in the side.
I spoke to my mate today that does all folding and cutting i need in alloy, he is willing to make these, with lexen lid or folded section like original picture.
About $175 each for the dimensions given by Phunky_monkey - plus shipping to Melb of course.
all folded , welded, recessed and Nut-serts and Allen key bolts.
Ryan - no need for the male to male fittings as that defeats the purpose as the connections are still outside of the box.. but can be done if you get the fittings needed to pass through 2.5mm alloy
Chris, thats cool but whats going to stop the smell getting out? The hoses will still need to go into the box some how. If you use proper jic fittings on the correct hose you will not get any smell outside the box.
then technically you dont need a box then :ninja:
the whole point of the enclosures really is for legallity - they must be seperated from the cabin by something... so if you have exposed hoses, your not going to get away with it on an ADR perspective. the correct hoses would remove fuel smell by default.
are you using JIC and not AN fittings? havent really seen JIC available many places.
My own system is mounted along the boot where the battery used to be, i'll be flanging it down to the stock fuel inspection cover so its totally sealed from the cabin, without anything exiting the sides of teh enclosure other than wiring.
any way you go, you will need to run grommets through the side of teh box, Jaycar have some great 3 piece screw on grommets than are waterproof (so leak proof for vapor)
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
