Seem to recall a mate who got his r34 gtt turbo highflowed from gcg turbos for 1700bux but they are in sydney so you could perhaps ship it down?, dont know if the prices have come down.
Any thought on buying a garrett item or hks? tad more expensive but you can always sell your old one to make up the difference.
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4108366
Depends how much you want to spend really... And if you want a ball bearing or journal bearing turbo. If you supply the turbo the highflowing/rebuilding cost is usually around 1000-1500 if you want to keep it journal bearing. Depending how cheap you find a second hand highflow or even a blown highflow would determine which path to travel. Rebuilding journal bearing turbo's is relatively cheap compared to a ball bearing.. as in 500-600 for a rebuild compared to 1000ish for a ball bearing rebuild.
If you get yours highflowed however you can be guaranteed that your banjo's and oil/water lines will line up... you also build a relationship with your workshop and get a warranty.
I don't know brisbane so can't help you out any further:)
Cheers.
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4108373
Cheers.
His turbo is already ball bearing.
Yes you can send yours to GCG in Sydney to high flow. I have one. Yes it's cheaper if you can find a blown turbo to send them then sell yours in good condition. I just blew mine so the choice was obvious.
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4108624
How does a GCG BB highflow compare to a similar sized HKS or Garret item?
Is the difference huge in performance and response?
Does Garret even make a direct bolt on incl. standard dump pattern for RB25?
Last time i looked, GCG was charging $1950 exchange.
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4108645
i thought of going through the gcg high flow route but iv decided to go for HKS GTRS which is muich more reliable than the gcg high flow and is also a direct bolt on kit for R33
from nengun its 2600 delivered minus the cost of selling your good conditioned turbo
gcg charge 2000 to high flow your standard turbo. so for the extra 300 odd definetely go HKS
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4109503
Mmm decisions decisions.
What sort of boost can a highflow handle?
GTRS's can easily do 20 psi i hear. Since they are fairly small they would spool to 20 psi pretty quick too!
Now I'm leaning towards the GTRS again...
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4109549
Go onto youtube and type in hks gt-rs; there is a bloke who posted like 9 videos of his gtst with the gt-rs and it is amazingly responsive, frys the tyres very easily.
it will change your mind on the highflow.
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4109737
Why rebuild or repair a turbo when its nearly the price of buying one new?. The HKS GTRS will love 2 bar.
:P ummmm for about 3 seconds before it pushes that much hot air it'll melt all 6 pistons.....way out of the GT-RS's efficiency rating.
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4109750
+ 1
the turbo looks brutal. perfect upgrade for GTS-T
Edited by DrewII
https://www.sau.com.au/forums/topic/234357-gcg-highflow/#findComment-4109937
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
