Hi,
I have just put my engine back in the car after being rebuilt and ran into a couple of problems.
1) theres a wire coming out of the same harness as the + battery lead but I am unsure if it goes on the + or the - as when I check the continuity it measures as being connected to the earth But I am unsure if this if because its going through something and connecting back to the car or not.
2) I got a 80mm Throttle body from BMI when they were still Buzz Engines in Sumner Park QLD, I have no idea what TPS suites it. and before you say contact BMI, Well I have tried but seeing they packed up shop and Moved to the USA last december and the only scaps of BMI here is a dude who bought the stock to see it off as BMI
Any help you can provide would be a great help if me getting my car finally finished.
https://www.sau.com.au/forums/topic/234362-two-questions-in-one/
I gave Petro-ject a call to see if they could match one up, they said they have one that they are pretty sure is off a Ford... I am using a Adaptronic ecu, so the signal range won;t be a problem and it supports a very large number of TPS options.
Is there anywhere else that sells Tps's for less that $150 which I got quoted?
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
