car going in for engine transplant depending on my cash resources either a rb30 conversion or rb25 once completed i'm giving it two months price will go up to $14500
CAR NO LONGER GOING FOR ENGINE TRANSPLANT AS DONT HAVE THE TIME
to4 turbo, top mount exhaust manifold, external waste gate, screamer pipe, blits blow off valve, front mount intercooler, plazmaman plenum chamber, 500cc injectors, splitfire coil packs, EMS stinger 4 ecu running picky backed from a mines tuned ecu, bosch fuel pump rated for 600Hp, front and rear strut braces, new shocks and super heavy duty lowered king springs all round, indash electronic dvd/cd/mp3,mp4 player with tv but i have no arial for the tv, HKS turbo timer, boost gauge, short shift kit, hicas lock bar. I have receipts and a dyno sheet proving 210RWKWs.
