Item: Toyota Supra RZ
1993 Model
xxx km’s
6 Months Registration
Website:
Item Condition: brand new engine package
Reason for Selling: not enough time to drive it
Price and Payment Conditions: $27500 ono
Extra Info: Engine
2JZ-GTE
JE Pistons (87mm)
Eagle Con Rods
ARP Head Studs
ARP Main Studs
HKS Head Gasket
HKS Timing Belt
HKS Cam Gears
ATI Harmonic Balancer
Turbonetics T72 Turbo
Tial 45mm External Wastegate
880cc Injectors with Custom Fuel Rail
SX Fuel Regulator
80mm Billet Throttle Body
Custom Made Stainless Steel Exhaust Manifold
FMIC with custom piping
3.5” Exhaust System, with Custom Dump Pipe
Bosch Individual Coil Packs
Microtech LTX12S ECU
2 x Bosch 044 Fuel Pumps
2L Surge Tank
Custom Radiator Overflow Tank (Polished Stainless Steel, Braided Lines & Speedflow Fittings)
Custom Oil Catch Can (Polished Stainless Steel, Braided Lines & Speedflow Fittings)
Polished Stainless Steel Radiator Pipe
Reconditioned Head
272 cams
New shims
Gearbox
Rebuilt Auto Gearbox (Manual valve body)
Transmission Oil Cooler
Rebuilt stall converter
Exterior
Alpine Silver
Super Low King Springs
20” BMS Rims with 275’s Rear 235’s Front (near new)
Clear side indicators
Tinted Windows
Electric Antenna
Remote central locking/keyless entry
Interior
Custom Pink & White Front and Rear Seats
Custom Pink Hood Lining Embossed
Custom Pink Gearstick surround
Pioneer CD/MD Player
Front and Rear Speakers
Sony Explode Amp
Turbo Timer
Electronic Boost Controller
Autometer Boost Gauge
Autometer Oil Pressure Gauge
Electric Windows/Mirrors
Electric Drivers Seat
Air Con/Heater
Pictures:
Contact Details: Josh on 0416 221 112
https://www.sau.com.au/forums/topic/234391-fully-built-supra/
It's not hers.....
it belongs to her boyfriend.........
the car is in need of a tune from what i've read in this thread...
http://www.most-wanted.com.au/forums/index.php?showtopic=24
gl with the sale though
Edited by JJay
It's not hers.....
thanks for that. but we both own it. is in both of our names. anyway!! car is being tuned this week will post figures once done bump
In all honesty Amy lee. you would broaden your sales potential immeasurably by having the car retrimmed in more mainstream colours.
There are few enough chicks in to high performance imports and even fewer (I hope) guys that want a pink interior.
If you maintain this one like you did your 33 It will be an exceptionally clean and well kept car for the next owner.
bump~ made 430hp on 22 psi. was tuned by matt spry. He has advise us to take the 20's off and it will make at least 60 more hp and that the auto has drained it
  • 1 month later...
  • 4 weeks later...
Actually if we are going to tell the truth, its not registered in either of your names which I would know as I still receive the rego papers for the car!!!!!!! It was sold to josh however!
Sad to see it being sold again I wish I had of kept her poor car!!
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
