Fully Built Supra
skyline_chick88
 Share
Item: Toyota Supra RZ
1993 Model
xxx km’s
6 Months Registration
Website:
Item Condition: brand new engine package
Reason for Selling: not enough time to drive it
Price and Payment Conditions: $27500 ono
Extra Info: Engine
2JZ-GTE
JE Pistons (87mm)
Eagle Con Rods
ARP Head Studs
ARP Main Studs
HKS Head Gasket
HKS Timing Belt
HKS Cam Gears
ATI Harmonic Balancer
Turbonetics T72 Turbo
Tial 45mm External Wastegate
880cc Injectors with Custom Fuel Rail
SX Fuel Regulator
80mm Billet Throttle Body
Custom Made Stainless Steel Exhaust Manifold
FMIC with custom piping
3.5” Exhaust System, with Custom Dump Pipe
Bosch Individual Coil Packs
Microtech LTX12S ECU
2 x Bosch 044 Fuel Pumps
2L Surge Tank
Custom Radiator Overflow Tank (Polished Stainless Steel, Braided Lines & Speedflow Fittings)
Custom Oil Catch Can (Polished Stainless Steel, Braided Lines & Speedflow Fittings)
Polished Stainless Steel Radiator Pipe
Reconditioned Head
272 cams
New shims
Gearbox
Rebuilt Auto Gearbox (Manual valve body)
Transmission Oil Cooler
Rebuilt stall converter
Exterior
Alpine Silver
Super Low King Springs
20” BMS Rims with 275’s Rear 235’s Front (near new)
Clear side indicators
Tinted Windows
Electric Antenna
Remote central locking/keyless entry
Interior
Custom Pink & White Front and Rear Seats
Custom Pink Hood Lining Embossed
Custom Pink Gearstick surround
Pioneer CD/MD Player
Front and Rear Speakers
Sony Explode Amp
Turbo Timer
Electronic Boost Controller
Autometer Boost Gauge
Autometer Oil Pressure Gauge
Electric Windows/Mirrors
Electric Drivers Seat
Air Con/Heater
Pictures:
Contact Details: Josh on 0416 221 112
It's not hers.....
it belongs to her boyfriend.........
the car is in need of a tune from what i've read in this thread...
http://www.most-wanted.com.au/forums/index.php?showtopic=24
gl with the sale though
thanks for that. but we both own it. is in both of our names. anyway!! car is being tuned this week will post figures once done bump
In all honesty Amy lee. you would broaden your sales potential immeasurably by having the car retrimmed in more mainstream colours.
There are few enough chicks in to high performance imports and even fewer (I hope) guys that want a pink interior.
If you maintain this one like you did your 33 It will be an exceptionally clean and well kept car for the next owner.
  • 1 month later...
  • 4 weeks later...
Actually if we are going to tell the truth, its not registered in either of your names which I would know as I still receive the rego papers for the car!!!!!!! It was sold to josh however!
Sad to see it being sold again I wish I had of kept her poor car!!
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
