  • Replies 321
i am cool as a cucumber when it comes to traffic etc.. in melbourne, but damn!! i was stressed something stupid on sat arvo navigating traffic!
the roads are dead set dangerous on their own, horrible is the only word to describe them...they like cement slabs all uneven and called roads....
slightly off topic...i put in about $90 aprox each way in fuel(premium stuff bout 99c/ltr) is that pretty average etc??
not many stone chips, just a couple on the drivers door
Ahh I see you've driven on Parramatta Rd ;)
I used up about $85 on the way there and about $70 on the way back (after the new exhaust was fitted) if that helps.
Guest neoGT-25
hey PVA...
what does your blitz pod sound like and how much is it? my pod is wierd.
now for my tale of my f**ked up chassis ;)
while me and my family were holidaying in melbourne we drove around alot... untill the last 4 days we were there my dad noticed some flaping sounds from the rear tyres, when he got out he bent down and noticed that half of the tyre was worn to the belts but the rest of it was full tread...
when we went to get new rear tyres the guy said to have it alligned so we followed his advice... but when the guy started to allign the car he couldent get it to match and was confused about it untill he noticed all the dents and bends on the left hand side of the crossmember :D
when we bought the car we got it inspected by an engineer and he said "small accident damage" but nothing like this! now me and my dad have to pay $1400 for the pannel beating and another $770 for the rear tyres and we need to do it soon because our tyres and getting screwed allredy :)
now my dad is thinking of sueing the engineer but i dont think he will win :D
anyway... thats life :D
caio
hey neoGT, what do u mean when u say ur pod sounds weird?? when i use to have the k&n pod in, it use to make an awesome induction noise, i liked it.
sorry to hear about ur car, sounds like ur engineer didnt do a good job of checking, any damage to the chasis is no good.
Cold Air intake
Blitz NA ECU engine management
Front and Rear Struts
white line Suspension pakages
DBA cross drilled and slotted Rotors
Endless beake pads
Redline engine oil and differential oils
17" ROH wheels YOKOHAMA tires
that's pretty much it!
Turbo would be nice!
If your car has No GO then for RICEY looks :D
cheers
Joe
Hey thanx heaps PVA your car sounds impressive! did all that stuff make much of a difference?
Im hoping to fit a turbo in a year or two so i dont know whether or not i should bother with any mods i spose i can do some things but i dont wanna spend heaps of money only 2 change it all when the turbo is fitted. Suspension package is deffineatly needed now
thanx:)
Not sure if it cones R34 NA... they are RB25DE Neo so I guess it is avaliable I had the list URL.... but lost it . :(
all above came with the car so I am not sure it made any differnce...
but everyone says to me it's pretty fast car for NA and AUTO :)
I dont really care it gets me to places A to B. :)
It will make baby R33 GTR from my R33 GTS-4 :)
R33 GTS4 + RB26DETT + $$$ = Baby GTR
cheers
Joe
Guest neoGT-25
guys, ive just figured what i want on my car! :(
MINE's VX-ROM :)
are they good? its a bit expensive (A$1837) but do you think its worth it?
what exaust's have you guys got on your cars? and also what mufflers? i want a A'PEXi N1 n/a muffler and it says they have them for the 33 GTS but i dont know if they have them for the 34 GT :)
please write back with any help you can give me. and thanks!
bye :burnout:
PS: soon im coing to make a list of all the things i want for my car, can you fellas please gimmie a few good or bad tips on my choices... thanks!
Guest neoGT-25
Here are the things i want so far... are they all good or crap?
(Whats the difference between the exchange price and the normal price?)
MINE's VX-ROM -----> (exchange price - A$1837) A$3367
A'PEXi N-1 muffler (N/A) -----> A$770
TIEN TYPE FLEX DAMPER -----> A$2771
nismo f&r STRUT BRACE BAR -----> A$544
A'PEXi GT Spec RADIATOR CAP (It helps with the pressure dosent it?) -----> A$52
BLITZ SONIC POWER AIR CLEANER -----> A$467
A'PEXi RSM + G-sensor -----> A$450?
i also need some guages, any ideas?
is there anything that i need thats not there apart from a turbo? i want my car to be a nice counding fast N/A line :)
thanks for any help you can give. :) byes :burnout:
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
