  • Replies 321
i am cool as a cucumber when it comes to traffic etc.. in melbourne, but damn!! i was stressed something stupid on sat arvo navigating traffic!
the roads are dead set dangerous on their own, horrible is the only word to describe them...they like cement slabs all uneven and called roads....
slightly off topic...i put in about $90 aprox each way in fuel(premium stuff bout 99c/ltr) is that pretty average etc??
not many stone chips, just a couple on the drivers door
Ahh I see you've driven on Parramatta Rd ;)
I used up about $85 on the way there and about $70 on the way back (after the new exhaust was fitted) if that helps.
Guest neoGT-25
hey PVA...
what does your blitz pod sound like and how much is it? my pod is wierd.
now for my tale of my f**ked up chassis ;)
while me and my family were holidaying in melbourne we drove around alot... untill the last 4 days we were there my dad noticed some flaping sounds from the rear tyres, when he got out he bent down and noticed that half of the tyre was worn to the belts but the rest of it was full tread...
when we went to get new rear tyres the guy said to have it alligned so we followed his advice... but when the guy started to allign the car he couldent get it to match and was confused about it untill he noticed all the dents and bends on the left hand side of the crossmember :D
when we bought the car we got it inspected by an engineer and he said "small accident damage" but nothing like this! now me and my dad have to pay $1400 for the pannel beating and another $770 for the rear tyres and we need to do it soon because our tyres and getting screwed allredy :)
now my dad is thinking of sueing the engineer but i dont think he will win :D
anyway... thats life :D
caio
hey neoGT, what do u mean when u say ur pod sounds weird?? when i use to have the k&n pod in, it use to make an awesome induction noise, i liked it.
sorry to hear about ur car, sounds like ur engineer didnt do a good job of checking, any damage to the chasis is no good.
Cold Air intake
Blitz NA ECU engine management
Front and Rear Struts
white line Suspension pakages
DBA cross drilled and slotted Rotors
Endless beake pads
Redline engine oil and differential oils
17" ROH wheels YOKOHAMA tires
that's pretty much it!
Turbo would be nice!
If your car has No GO then for RICEY looks :D
cheers
Joe
Hey thanx heaps PVA your car sounds impressive! did all that stuff make much of a difference?
Im hoping to fit a turbo in a year or two so i dont know whether or not i should bother with any mods i spose i can do some things but i dont wanna spend heaps of money only 2 change it all when the turbo is fitted. Suspension package is deffineatly needed now
thanx:)
Not sure if it cones R34 NA... they are RB25DE Neo so I guess it is avaliable I had the list URL.... but lost it . :(
all above came with the car so I am not sure it made any differnce...
but everyone says to me it's pretty fast car for NA and AUTO :)
I dont really care it gets me to places A to B. :)
It will make baby R33 GTR from my R33 GTS-4 :)
R33 GTS4 + RB26DETT + $$$ = Baby GTR
cheers
Joe
Guest neoGT-25
guys, ive just figured what i want on my car! :(
MINE's VX-ROM :)
are they good? its a bit expensive (A$1837) but do you think its worth it?
what exaust's have you guys got on your cars? and also what mufflers? i want a A'PEXi N1 n/a muffler and it says they have them for the 33 GTS but i dont know if they have them for the 34 GT :)
please write back with any help you can give me. and thanks!
bye :burnout:
PS: soon im coing to make a list of all the things i want for my car, can you fellas please gimmie a few good or bad tips on my choices... thanks!
Guest neoGT-25
Here are the things i want so far... are they all good or crap?
(Whats the difference between the exchange price and the normal price?)
MINE's VX-ROM -----> (exchange price - A$1837) A$3367
A'PEXi N-1 muffler (N/A) -----> A$770
TIEN TYPE FLEX DAMPER -----> A$2771
nismo f&r STRUT BRACE BAR -----> A$544
A'PEXi GT Spec RADIATOR CAP (It helps with the pressure dosent it?) -----> A$52
BLITZ SONIC POWER AIR CLEANER -----> A$467
A'PEXi RSM + G-sensor -----> A$450?
i also need some guages, any ideas?
is there anything that i need thats not there apart from a turbo? i want my car to be a nice counding fast N/A line :)
thanks for any help you can give. :) byes :burnout:
    • I don't know how this is even possible. I removed the strut to do some work (it came out fine, and keeping in mind that I didn't put things back in the same order, but did this on purpose because I was supposed to remove the strut originally instead I tried to remove other shit first which made things a head ache) but now the problem is that it won't go back in. The alignment between where the bolt hole for the strut is and the j arm where the strut slides onto is way off, about a 10cm difference or more. In order to make it fit I'd somehow need to push it up. I tried to compress it with a spring compressor and install it but the compressor was getting in the way and there was no working room. On the photo you can see the difference between the shock and the thread that it's supposed to go on. The only things I removed in total were - the top bolts for the j arm but I didn't remove the actual j arm - the 3 bolts that hold the plate for the brake lines - the sway bar link (this bolted on back fine) - the strut/shock absorber
    • LOL that sounds pretty conclusive! Yeah if it doesn't work on a tight nut, it doesn't work.
    • Been a while since I've heard anyone mention Kumho tyres. It's like they've fallen off the radar in terms of street/track tyres. I still want to get below 1m50s on the RS-4 tyres at SMSP, just because lol. Even doing a 1m52s lap, going into T1 was sketchy af.
    • I've run most of the semis which are available and sadly you can pretty much rank them by price.  Fast and spendy = Z221, A050, DZ03G Ok and mid range price = R888, V70A, A052 I don't really rate the AR-1 because it's not cheap enough for the performance level offered. Yes, they're much cheaper than A050 but V70A can be had just as cheap and is a much faster and more predictable tyre.
    • There's no current law that stipulates that you cannot eat dessert with a soup spoon, although, it is socially unacceptable of course, shame on you But, there are emissions laws, which is sort of on topic to the OP's questions Things like emissions are, if anything, going to get stricter in the future for road registered cars I believe, 'Merica has yearly emisions testing in some states, the UK has it's yearly MOT testing as well which includes emissions Building, and purchasing modified vehicles may become alot more problematic if you want to keep them registered, how, if, and when each state handles this is anyone's guess  More food for thought really
