  • Replies 321
omg the extractors are teh bomb... they make a sweet noise when I give it gas, having driven a stock GTS and mine, it makes a big difference. The engine revs a lot smoother too.
I even got the jap manual, the bill for purchase and fitting by a performance shop in japan, and a sticker for it, which was never attached.
I also got an HKS airbox... but I haven't tried any alternative CAI methods so I can't compare it to anything.
I'm gonna do some light mods to the car, what do you guys recommend to get the most out of the N/A?
hi all... im relatively new to the Skyline world, having only just bought one ~6months ago, but like everyone else, am looking for more power... I only have an R32 GTS Type-S (RB20DE), so am not expecting miracles, but being beaten by any commodore is just embarrasing...
Having read all of the previous posts on Exhausts/extractors/CAIs etc, im wondering whether its worth the effort of staying NA. All the same, When i bought the car, she already had a 3" high flow system, of some japanese origin, but i think the headers are only factory (not a manifold though). The air box on the 32 is fed from under the headlight assembly anyway, so would a CAI or Pod filter help at all? You guys sound like you'd know more about this than me, so any help will be great.. Cheers, Phil
well in that case, can you tell me what badges yours has? coz some ...unmentionable... has gone to all the trouble of RIPPING ALL MINE OFF !!! bastard... anyways, it was before i got it, and i have never seen another one (i live in a small town) close enough to work out what im meant to have. All i can see is the outlines on the front arches where the GT badges were.
3" is way to big for a NA 2.0 litre, I've got a 2 1/2" exhaust system on my 2.5 litre and I wouldn't go any bigger. If you're going to keep the car NA, get a hold of some extractors (there's a group buy set up at the moment, to get Cobe's for around the $300 mark), and if you're going to slap on a pod filter, make sure you sheild it so it doesn't suck in the hot air from around the engine.
At the end of the day though, you're pretty limited with what you can get out of the 2.0 litre engine.
i would have to agree that 3" is probably a *Little* bit of overkill for 2 litres... but it's not like its a 2-stroke requiring a tuned back-pressure, is it? i dunno... all the same, i am also aware that theres not much to do with that small capacity, but at my age, there is no way i can insure a forced aspro car of ANY sort, (but lets face it, after owning a Skyline, what else would you have?) so im trying to make the best of what i've got.
The air intake is another matter, because im SURE you can't get too much air. And i fitted a pair of driving lights the other week, and found that behind the side intake of the GTR front bar (again, a waste on a GTS) is a gaping cavity with nothing in it. Would it be worth trying to tap the pod filter into this area, as it would then be drawing fully from the open air in front, which would obviously be the coldest. Anyone else tried this before? suggestions?
hey guys i got the same extractors as the one in the group buy
i found em here in sydney paid a little bit more than the group buy price though
just comparing the old headers to the new ones you could tell that the new ones would perform better but i wasnt expecting much difference from them but boy was i surprised
i have a 2.5 inch cat back exhaust, stock cat and the coby extractors i also have a cold air induction
once the extractors were installed i noticed straight away that the car sounded meaner and more open it also reved smoother and quicker i regaind alot of the low down power i lost when i put the exhaust on
so just lettting u guys know im very happy with em
hopefully u guys will be too
anf
yea i was so close to changing it to a 2.25" but i thought ill wait till the extractors go on then i would decide wat to do but it seems ok now
i tightened the accelerator cable too cause there was a sh*tload of slack
    • I don't know how this is even possible. I removed the strut to do some work (it came out fine, and keeping in mind that I didn't put things back in the same order, but did this on purpose because I was supposed to remove the strut originally instead I tried to remove other shit first which made things a head ache) but now the problem is that it won't go back in. The alignment between where the bolt hole for the strut is and the j arm where the strut slides onto is way off, about a 10cm difference or more. In order to make it fit I'd somehow need to push it up. I tried to compress it with a spring compressor and install it but the compressor was getting in the way and there was no working room. On the photo you can see the difference between the shock and the thread that it's supposed to go on. The only things I removed in total were - the top bolts for the j arm but I didn't remove the actual j arm - the 3 bolts that hold the plate for the brake lines - the sway bar link (this bolted on back fine) - the strut/shock absorber
    • LOL that sounds pretty conclusive! Yeah if it doesn't work on a tight nut, it doesn't work.
    • Been a while since I've heard anyone mention Kumho tyres. It's like they've fallen off the radar in terms of street/track tyres. I still want to get below 1m50s on the RS-4 tyres at SMSP, just because lol. Even doing a 1m52s lap, going into T1 was sketchy af.
    • I've run most of the semis which are available and sadly you can pretty much rank them by price.  Fast and spendy = Z221, A050, DZ03G Ok and mid range price = R888, V70A, A052 I don't really rate the AR-1 because it's not cheap enough for the performance level offered. Yes, they're much cheaper than A050 but V70A can be had just as cheap and is a much faster and more predictable tyre.
    • There's no current law that stipulates that you cannot eat dessert with a soup spoon, although, it is socially unacceptable of course, shame on you But, there are emissions laws, which is sort of on topic to the OP's questions Things like emissions are, if anything, going to get stricter in the future for road registered cars I believe, 'Merica has yearly emisions testing in some states, the UK has it's yearly MOT testing as well which includes emissions Building, and purchasing modified vehicles may become alot more problematic if you want to keep them registered, how, if, and when each state handles this is anyone's guess  More food for thought really
