  • Replies 321
omg the extractors are teh bomb... they make a sweet noise when I give it gas, having driven a stock GTS and mine, it makes a big difference. The engine revs a lot smoother too.
I even got the jap manual, the bill for purchase and fitting by a performance shop in japan, and a sticker for it, which was never attached.
I also got an HKS airbox... but I haven't tried any alternative CAI methods so I can't compare it to anything.
I'm gonna do some light mods to the car, what do you guys recommend to get the most out of the N/A?
hi all... im relatively new to the Skyline world, having only just bought one ~6months ago, but like everyone else, am looking for more power... I only have an R32 GTS Type-S (RB20DE), so am not expecting miracles, but being beaten by any commodore is just embarrasing...
Having read all of the previous posts on Exhausts/extractors/CAIs etc, im wondering whether its worth the effort of staying NA. All the same, When i bought the car, she already had a 3" high flow system, of some japanese origin, but i think the headers are only factory (not a manifold though). The air box on the 32 is fed from under the headlight assembly anyway, so would a CAI or Pod filter help at all? You guys sound like you'd know more about this than me, so any help will be great.. Cheers, Phil
well in that case, can you tell me what badges yours has? coz some ...unmentionable... has gone to all the trouble of RIPPING ALL MINE OFF !!! bastard... anyways, it was before i got it, and i have never seen another one (i live in a small town) close enough to work out what im meant to have. All i can see is the outlines on the front arches where the GT badges were.
3" is way to big for a NA 2.0 litre, I've got a 2 1/2" exhaust system on my 2.5 litre and I wouldn't go any bigger. If you're going to keep the car NA, get a hold of some extractors (there's a group buy set up at the moment, to get Cobe's for around the $300 mark), and if you're going to slap on a pod filter, make sure you sheild it so it doesn't suck in the hot air from around the engine.
At the end of the day though, you're pretty limited with what you can get out of the 2.0 litre engine.
i would have to agree that 3" is probably a *Little* bit of overkill for 2 litres... but it's not like its a 2-stroke requiring a tuned back-pressure, is it? i dunno... all the same, i am also aware that theres not much to do with that small capacity, but at my age, there is no way i can insure a forced aspro car of ANY sort, (but lets face it, after owning a Skyline, what else would you have?) so im trying to make the best of what i've got.
The air intake is another matter, because im SURE you can't get too much air. And i fitted a pair of driving lights the other week, and found that behind the side intake of the GTR front bar (again, a waste on a GTS) is a gaping cavity with nothing in it. Would it be worth trying to tap the pod filter into this area, as it would then be drawing fully from the open air in front, which would obviously be the coldest. Anyone else tried this before? suggestions?
hey guys i got the same extractors as the one in the group buy
i found em here in sydney paid a little bit more than the group buy price though
just comparing the old headers to the new ones you could tell that the new ones would perform better but i wasnt expecting much difference from them but boy was i surprised
i have a 2.5 inch cat back exhaust, stock cat and the coby extractors i also have a cold air induction
once the extractors were installed i noticed straight away that the car sounded meaner and more open it also reved smoother and quicker i regaind alot of the low down power i lost when i put the exhaust on
so just lettting u guys know im very happy with em
hopefully u guys will be too
anf
yea i was so close to changing it to a 2.25" but i thought ill wait till the extractors go on then i would decide wat to do but it seems ok now
i tightened the accelerator cable too cause there was a sh*tload of slack
    • Yeah, whenever I say "HP", I mean HP. As in, at the engine. Allowing for a 25% discount from engine to typical Ozzie braked roller dyno figures, then subtracting the usual (more optimistic) US inertia dyno offset..... you get into the 600 actual engine HP territory from your 484 wheel number. 484 / 0.75 = 645   (that's Aussie rw intertia HP, converting to approximate engine HP. 645 --> 600 is discount for inertia dyno. Could actually be worse than that. But that would still be up around 600. So near enough for purposes.
    • Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm.
    • i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
    • Nice. 600ish HP is probably a nice place to be.
    • In the US the EPA has been going after shops that sold aftermarket ECU tuning software that allowed you to disable CELs for things like EGR, DPF, SCR, or TWC failure. They also went after shops for selling emissions delete equipment. Their logic is that all cars built for street use have this emissions equipment and you cannot do an after the fact conversion to an off-road vehicle not intended for street use. Cobb, Hondata, and similar companies have basically all revised their tuning software such that going forward you cannot suppress DTCs for emissions-critical systems, nor can you toggle systems on and off in the tune like EGR. You also cannot adjust OBD emissions monitoring logic. You can still tune these cars. But you have to do things the hard way, basically. For example Subaru FA20DITs used to delete the TGV system to get spare analog IO for a flex fuel sensor. EGR also has to be dramatically pared back because without the TGVs the stock EGR map causes bad misfires. Now instead they have to implement the flex fuel system as a CAN bus sensor instead. IMO, this is heavy-handed but the EPA in the US gave so much leeway for so long and the aftermarket relentlessly abused that leeway to the point that they could actually see the effects of all these emissions-deleted work trucks on their air quality monitoring for cities that haven't met Clean Air Act standards. It's one thing to have a few people deleting emissions on their weekend car that spends 9 months out of the year on jack stands. It's another thing entirely for entire fleets of tradies driving around 8 hours a day on deleted diesels that emit 1000x the emissions per mile of a compliant vehicle.
