http://www1.biz.biglobe.ne.jp/~GT-R/autech32.html
have a look at this if your interested in the Autech RB26DE
it has some damn nice extractors, 6 individual throttles(!)
has an r32 body shell, though its a bit heavy for my like'n, 1480 kg
that figure sounds more like an r32 GTr
Im a huge na skyline fan, i would freakin love this car !!
  • Replies 321
Oh and by the way, the basic specs are (to the best of my ability)
4580~1695~1360 mm
ƒƒzƒC[ƒ‹ƒx[ƒX„@@@@@2615 mm
ƒweight„@@@@@@@@1480kg
ƒengine„@@@@@@RB26DE
ƒpower stroke„@@@@@@@@220PS /6800rpm
ƒtork„@@@@@@@25.0kgm/5200rpm
ƒwheels„@@@@@@@@@205/55R16 88V
For us engols speakers:
It goes with 32 R and as for NISSAN which is overtaken, 4 door editions GT whose request from the part owner extra troop is many - it announces 4 doors Gts-4 of 32 where even R you can say based AUTECH VERSION. With the photograph it is understood a little and perhaps, the ‚¸ leprosy, but the ornament has become SKYLINE26. On the rear the spoiler for 4 doors is attached with option.
Å‚o—Í:220PS/6800rpm
Å‘åƒgƒ‹ƒN:25.0kgm/5200rpm.
The rich torque which extremely occurs low from revolution, made nimble takeoff acceleration possible. The power which reacts to linear in throttle work. Passing power peak, the smooth blowing rising which continues. It is low, you can taste the good quality of the natural air intake engine which reacts sensitively to the movement of the accelerator from the rotary limits to the high rotary limits. Basic mechanism the ‚× - to designate RB26DETT which has the result as a racing engine as ƒX, the intake, as for exhaust, the camshaft and the piston etc. the Otech special made. Special tuning for this engine is included in the control computer. As for exhaust manifold stainless steel make isometric flexible pipe. Exhaust interference is avoided, charm twin cam sound is given Qin coming out. Actualization of the high braking efficiency where it corresponds to the power efficiency which is superior. In order reduction of unsprung weight and to increase heat dissipation characteristic, the caliper of the ƒAƒmƒŒƒ~ alloy make - with it has done. Front opposition 4 piston, rear opposition 2 piston. As for the brake rotor, the turbo fin model large-sized ventilated disk which has the sliding surface pin hole. As for rotor diameter, front: 296mm and rear: 292mm. Controlling this powerful braking effort effectively is ABS (the anti lock brake system). With control of synthesis with the drive system, ABS original antiskid efficiency and the braking efficiency which in the road surface which the snow ˜G and the like it is easy to slide are superior are shown. As for suspension layout 4 wheel multiple link suspension. It has made the specification whose rigidity is high making provision for the increase of 4WD conversion and suspension input. In addition Bridgestone EXPEDIA S-01 (205/55 R16 88v) you prepared in the private tire. As for tuning of suspension system, low as for the medium speed limits the cornering efficiency where in the high-speed limits are high from the first it has been compatible the riding comfort which is superior beautifully. The sense of security and the mild riding comfort which feeling inhales to the last exactly in the road surface and is attached. If crew-member everyone tastes, there is a real value of this underside in very the sense of relief which is not.
(From catalog part excerpt)
Guest neoGT-25
THAT LOOKS MAD!
and thanks for the advice guys... so to get it right, the 2.25" would be more responsive than the 2.5"? could you guys please explain? :)
and also should i get stainless?
thanks all... byes ;)
PS: Im getting a datto 1600 as a runaround car :burnout: (haha ill put a SR20DET in it ;)) not really :)
well the exaust should be stainless because alot of water vapour goes through the exaust, and if it isnt rust proof then eventually you will have leaks in the pipe work, this will make the car loud as hell.
While gettin the 2.25 will increase response over the 2.5 because it has less back pressure, or in other words it should have a bit more torque down low in the rev range. This addition of torque will make the car more fun and responsive to drive. It will also has less drone in the cabin.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
