As per the title, should i get a set of Cam gears for my GTR with mild upgrades, ie exhaust, boost , filter?
Im getting my timing belt done, so i thought i would get this done @ the same time. Also what brand of gears should i get? I've heard of HKS gears ripping timing belts.
https://www.sau.com.au/forums/topic/234431-cam-gears-for-rb26/
Yep, definetely a good invest on a RB26 especially if your doing the timing belt. Good gains can be had with a bit of playing around with the pulleys.
As for what brand, it was the old HKS ones that were a problem. Nowadays they are all pretty much the same so just grab what ever cheap ones you can from one of the traders here.
If you do something like power FC + boost (14psi or so) and cam gears with a good tune makes 240-260rwkw in a GTR.
Without cam gears you normally won't make that much stock....(assuming exhaust and cat are done).
i got my gears done
mines at 220awk (std dumps)
my mechanic put them in for 100-150 round about
i noticed that it isnt as flat at the low revs (which was pissing me off) - worth the while, ive seen a couple of tomei sets go for 220-240 on the forums which is a decent price!
so yes, DOO ITT!!
i got my gears done
so yes, DOO ITT!!
oh sounds great, my car feels a little sluggish at lower revs so it might be a good investment. Thanks for the tip, ill grab a tomei set asap.
Cam gears an stock cams are the way to go, even well into the 300rwkw range.
just change the cam belt when your doing the cams, good for another 80,000 or whatever and ya don't need to think about it again for a few years
Yep, for best results get it tuned
You can always install them and set them to '0' where they will work as standard CAM gears would but if your playing with them, advancing and retarding its best to do it on the dyno to ensure the mixtures are still good and the car isn’t pinging
I've always wondered what’s good to use as well but there is so much cheap stuff flying around you don't know what’s good and what’s not.. I would stick with Jap brands just to be safe
New series HKS, GREDDY, OS GIKEN, TOMEI are all good and easily available
Now as for brands, what do people trust on their cars??
i was going to get a set of fidanza ones from the us but was told not to...
personally I would never put the cheap ones on an RB26 of mine. I have used trust (probably my top choice), HKS (the mk II ones), and just put tomei on the current engine (as I have tomei cams I thought I'd match). All of those have performed well. The other 'ok' choice is standard gears modified with a new centre. if it is done well they should be just as reliable as standard gears (which are of course very reliable). It's a good choice as you still have the strong stock gear face, just an adjustable centre. the cheap alloy gears in my book are a no no.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
