Ahh yeah as title says... as silly as it seems... I blew my old turbo and bought a highflowed one second hand. It was near new and had no shaft play. I had it quickly checked by MTQ up here and he said it looked good.
Now yesterday i put it all on exactly the same as i pulled it off... got the car running fine... except when i pull the throttle cable or go for a little drive there's NO boost and when there's meant to be boost it blows slight smoke (from running too rich from no boost i presume). The new highflow came with a hks actuator which is what i originally thought MIGHT be the problem... so i put the standard one on from the old turbo and no difference...
The wastegate valve stays shut the whole time and the shaft doesn't move at all under throttle and no spool/doesn't go above 0 on the boost gauge.
Both the exhaust and compressor wheels spin freely and at the same time (one spins the other obviously). I did have an exhaust leak between the manifold and the turbo but put a new gasket in there this morning and now it's gone.. but same problem... not going above 0 only staying in vacuum. I've checked all the intercooler pipes/vacuum lines etc etc and am now stuck. I would think it would be something fairly obvious!
So if anyone has any suggestions of what it could be please help me out... I really don't want to think it's the turbo afterall but if anyone can help me before i start pulling it all off again i'd much appreciate it!
Thankyou in advance...
Steve.
  • Replies 60
wastegate flap stuck open
intercooler pipework loose or leaking
vac lines loose or leaking
basically its leaking pressure or the wastegate is always open
thus the turbocharger nevers gets to spin fast enough and doesnt build any positive pressure
wastegate stays closed.. actuator doesn't move.. could a small vacuum leak eg in the rubber snorkel or something make it produce NO boost? It sorta sounds like there's an air-ie noise coming from that side and no not from the air filter lol. I'll keep looking but yeah.
So a vacuum leak could stop it producing boost/spooling and therefore stop the wastegate from opening???
Okay i took the rubber snorkel off from the turbo and thus removing afm as well... and started the car and it idled fine and when i rev it a bit i can see the compressor wheel spinning.. so it's definitely capable of producing boost... it's just not??:s
bov should be alright... haven't touched that at all and yeah once again it's getting no spool or positive pressure whatsoever..
Damn cars. I'm sure it'll be something really obvious that i'll kick myself for but i've checked everything 1000 times and pulled off/put on as well. hmmmmmmmmm
Hey both. I was free revving it at first then i thought no i'll take it for a drive... went about 100m up the street and back and i accelerated just hard enough to where the turbo should be spooling.. maybe went to 3000rpm but there was nothing. Was just running really rich.
It's highflowed it shouldn't be that different coming on boost pretty much same as before. The blowoff valve doesn't make a single noise either..
Alright i took it for a bit of a harder drive just then and i can get the bov to open very very slightly but boost still isn't above 0 and yeah.
When idling how fast is the turbo supposed to be spinning??
I doubt 3000 rpm is going to produce any boost. It is highly unlikely to produce any on a "free rev" (even @ 6000) . You need to load up the engine to get boost.
Also, check ALL the intercooler piping between the compressor and the throttle and confirm all the joints are intact.
Well before i could just give the throttle cable a tug and the turbo would spool and then the bov would sound... now it's doing neither... and no matter what i do/how i drive i can't get the turbo to spool or produce boost. If i go for a hardish drive down the street the boost gauge doesn't even get close to the 0 on the gauge... However both wheels are spinning, wastegate flap opens and closes when disconnected from the arm.. the actuator spring is working fine when i pull it... and hmmmm
Thanks for everyone help. I'm starting to consider the possibility that it's the turbo... Anyone else think that's a possibility?? Is the compressor wheel supposed to be slowly spinning when it's just on idle? I can concentrate on one blade the whole time it's spinning that slowly.. but if i pull the throttle it spins rapidly like you'd expect it should..
i still think its possible (unlikely i know) that it could be the compressor nut tension.
it could be loose enough that at idle & free rev it doesnt spin on the shaft but when the turbine really gets moving the comp wheel could spin/slow down & not create boost.
im not saying thats yur problem but it is possible i believe.
good luck
Well if it's that i should let it idle like before without the afm and see if the shaft is spinning faster than the compressor wheel.. I'll give that a go or see if i can tighten the nut at all.
Your boost gauge is connected / working? If it's spinning wheels, then I would hazard a guess that you have some additional power from boost happening.
Maybe it's such a large turbo that it doesn't produce boost until quite high revs and loads.
no, what i mean is it might not start spinning on the shaft until the turbine/shaft is under load.
to be able to tighten the nut you will need to remove the dump, like i said this is just a suggestion to what might be wrong, hopefully its something easier.
Well i just checked all the intercooler pipes again... let it run and got a mate to yank the throttle cable and felt them all to see if I could feel any air escaping but they all seem fine and i can't get any movement out of them at all if i shake them around... all the vac lines are perfect and i can blow through all of them so there's no blockage... and they're on exactly the same as before..
Another funny thing... not sure if this is normal or not... but when i started the car the compressor wheel was spinning really slowly... then if i give it a squirt it starts spinning quickly and keeps spinning quickly even when it drops back to idle revs.... is that normal?? Is the turbo supposed to change rpm like that...
I guess thats the turbo gaining RPM and then not returning to its normal spool speed as the momentum is still rotating it (hence why people use turbo timers, to give the turbo time to reduce its RPM)
Very strange indeed. No blocked cat or something like that choking up the whole car?
Edited by Granthem
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
