  • Replies 60
Err not that it's really going to help much.... but anything stand out obvious wrong from these couple of photos lol. The oil feed banjo isn't sealing 100%.. i need to fix that but I don't think that would be doing it..
Hey yeah there is a gasket... It doesn't go to 0 straight away.. if i drive it it slowly climbs to a tiny bit below 0 and then doesn't go up any higher even if foot is flat.. grrrrr
that sounds like a problem, as putting ure foot down to the floor regardless where in a non turbo motor should give 0 vaccume, and on a turbo motor should give 0 vaccume then boost, i just added you on msn so i can ask you about it there instead of in a million posts
Hey yeah i can the wastegate flips open and closed without the arm attached to it just as easily as the old one.
I just went for another drive.... a big one this time... at 47% throttle (i went more than this) it's 58% airflow @ 4600rpm. It's like nothing nothing nothing then if i give it more the boost goes up to like 5psi and then when i back off the bov goes off like normal but the turbo makes a really faint spool like it does when you blow a cooler pipe so perhaps it is just leaking somewhere afterall.. Is a highflow going to make it THAT much laggier?:s Perhaps it's been bored out too much?? Doubtful as it still utilizes the same front and rear housings. I'm just waiting for someone to say that it will be different to drive with a highflow than standard but it's not that..
Which leads me to my next question... if the turbo is capable of producing even small amount of boost does that rule out that the turbo is the problem?? Or not necessarily...
*checks all hoses and piping again..*
Thanks for everyones help...
if the gate was stuck open it would go into vacuum instantly no problems and build some boost
it would just be mega laggy to build a useful amount of boost
but getting to 0 should be almost instant with gate leaking or not
it sounds like your manifold isnt pressurize, ie; your engine is atmo
this explains why you cant reach 0 vacuum
Yeah maybe you just forgot to tighten a hose clamp and its half blown off.
If its a bush bearing highflow it will be laggier again over a turbo thats BB of the same specs or a standard turbo. It won't deliver the boost as nice as a BB.
Yeah i'm gonna pull the dump pipe back off... make sure the wastegate flap is 110% closing correctly and make sure the arm is pulling it shut... when that's off also make sure the wheels are still spinning together and are tight... after that I think there's nothing more i can really do and will gladly pay a shop to fix whatever it is.
im having a brain fart but it seems like I have had this problem before. Maybe some how that turbo is out of spec?? The boost is suppose to be built up in the compressor housing and then distributed throught out the intercooler piping. Almost sounds like it may be sucking but not pushing if ya know what I mean. check the gasket on the comp housing. I think that fixed my problem before. It suxed trying to find one. or take the turbo off and get it checked by a pro. Or if ya have a freind with anouther turbo borrow it.
Good luck
Just had another look at pics.
1) Move your pressure source AWAY from your FPR.
You should NEVER tee things off the FPR signal line. You can cause pressure drops when putting things on that flow air etc.
2) Your hose clamps on the hot side of the intercooler to turbo seem to not be sitting right. Undo them, line them back up, redo them.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
