Yeah a mate just suggested it might be the cat blocked.... my dump front and cat are all welded together... i checked the other end of it when i pulled it off the other day and it seemed alright.. i had to turn it upside down and bang it on the concrete and the old turbo wheel and sh!t came out but maybe it did more damage?? completely blocked it up?? That would make it have massive backpressure and not be able to spool up right?
  • Replies 60
didnt think of that, could have leftovers from the old turbo lodged in the cat
anyways as someone already said... and i know its simple an more then likely not this, but is ur boost gauge connected properly? i.e when under vacum the hose is sucking itself into a sealed position on the back but then when it makes boost its blowing off so that its not sealing.
dare say that blockage in the exhaust is a good one
If the wheel has hit the honeycomb material in the cat there is a fair chance its done some damage. It can very easily collapse and be pushed to the rear of the cat where it becomes lodged.
Cut the cat off, fair chance your problem could be lodged there :)
Edited by Granthem
ahh well i just spent a few hours pulling the dump and cat off... i smashed all the honeycomb out and stuck the hose through it (closest thing i could find) and the nozzle came out the other end of it... so there's no restriction in that.. and the side of the cat i could see (catback side) was fine.
Started the car up.... no difference... same thing...............................................................
Dammit!
Dammit!
sorry to hear that, did you check/try to tighten the comp wheel while you had the dump off?
i know this might sound a tad silly as its so bvious but have ya checked the exhaust wheel coz without one you wont be makin boost?? or ur exhaust wheel may be damaged so its not makin boost??
just a suggestion
I was actually in such a hurry to start it up with the cat hollowed out that i started bolting it back on and forget to look up at the exhaust wheel... but it will be the same as it was when it was off a day before... yes there is an exhaust wheel.... i've also though that... coz i had to drive home when i blew the old one and yeah kinda feels the same... just not pouring smoke out like it did with the blown one.
The front wheel on the old turbo had 2 blades that were very slightly chipped... i'm not sure if that was done at the same time or if it was from ages ago... I don't think that would have done much though?? What do you's think??
I just can't accept that it's the turbo... it's 100km old (then previous car got written off) and looks immaculate/spins really well... the wheels aren't rubbing on the housing or anything... no noises... I'm at witts end with it I don't know whether to just take it to a shop or...
Here's the turbo...
Edited by JET-25L
Err no it doesn't... that's a steel wheel and you can tell it's been highflowed and bored out because both the wheels are way bigger than standard and on the standard turbo there is a raised edge around the exhaust wheel... whereas this one is level.. only way they can do it without changing housings.
Is it even possible for the exhaust wheel to be spinning on the shaft?? That can't even get tightened by the looks of it.. If it can I have no idea how to anyway.. If i try and spin the front one way and the back the other it doesn't work... and there's no up/down side to side play or anything like that so...
Blocked intercooler from blades of the front of the old turbo???:s
from what you said the old turbo comp wheel didnt break apart so that shouldnt have blocked up the cooler. oil from the old turbo can block it up if seals went.
where does your boost gauge get its pressure signal from? before the cooler or after?
no its not possible for the turbine/exhaust wheel to spin on the shaft, but it is possible for the comp wheel if not torqued/assembled correctly to spin on the shaft.
Edited by NWR31
take the turbo off, and take it to someone who fixes them or can have a look. i would be able to suggest someone here in sydney/woolongong. but your in townsville.
if the turbo spins freely when it was out of the car, and everything has gone back on correctly
its either going to be something very very silly. or as people have said the turbo isnt right..
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
