basically what you need to do is get the velo side mounts, and some sliders (cobra ones are good, and well priced). then you need to make a base frame that bolts to the floor of the car and allows you to bolt the sliders to the base frame. then the side mounts to the sliders, then the seat to the side mounts. any reasonably competent welder can make the base frame for you.
ok thanks for the tips.
I'm thinking as it's a track car, it doesn't really need to move forward/back - so just eliminate the slider part and make a base plate for side mounts...
should be ok?
what thickness metal and type should i use for the base frame?
thanks
-Matt
