Hey,
Ive recently picked up a hiflow rb20 turbo to put into my 1993 r32 gtst.
Half way through swap-over, turns out that my standard oil feed banjo bolt was LARGER than the hole in the hiflow..
Thus raising the question;
Did the rb20 turbo come with different size banjo bolt?
Is the series 1 (1989-1991) r32 rb20 banjo bolt the same?
Is the cefiro rb20 banjo bolt smaller/larger?
Trying to work out why the hole is smaller :P
edit: the housing has the numbers "16v5" on it.
From what ive read, the "5" refers to the year of production.
Can anyone confirm this?
Also, a bonus question; what info should i provide pirtek/enzed with when making a new oil/water lines.
Can i show up with the hiflow and tell them to match a bolt for the hole + lines?
What length should I get for both lines?
kthnxbye :D
https://www.sau.com.au/forums/topic/234457-rb20-turbo-banjo-bolt-size/
funny you post this as i have had the same problem recently...i have a rb20 in my s13, installed a rb25 turbo, run fine, till i blew it (due to stupid reasons dw), so i looked at putting an rb20 turbo on as they cheap as chips n i only want it for a run around now. I had one from a makes car..fitting it up fine then realised it had a faulty exhuast wheel, btw this turbo came of a 93 modle r32gts-t. So i bought one the other night from a forum, was a rb20 turbo, so i went to install this and realised the water feed and return lines are different! there are slightly smaller. So i rang nissan today they said possibly it was an older model one? $75.00 each of the lines (feed/return) so i opted out there. went to a mobile auto hose guy he provided me the right side banjo bolts and fittings which i used to fit up cutting the original hosing and inserted rubber and clamped. she all good now!! Hame
p.s sorry for the book of a post.
oki, turns out that redtop rb20 turbo's have a smaller banjo bolt. Hence why my silvertop water lines dont fit into the hiflow.
This explains why your rb20 turbo didnt fit your car, as the silvertop rb20/rb25 have larger oil lines than redtop rb20's.
In order to fix, all i need to get is redtop water lines :D So nissan was technically right in regards to an older turbo. (older than r32)
Case closed
Thanks
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
