I cant do donuts or drift as my car is now, so i`ve been looking for a replacement insides.
I drive 90% street and 10% track.
have found some on nengun.
http://www.nengun.com/cusco/lsd-type-rs
http://www.nengun.com/kaaz/lsd
http://www.nengun.com/nismo/gt-lsd-tt-pro
http://www.nengun.com/nismo/gt-lsd-pro
What do you guys think will be best for me ? Is there timeconsuming and/or difficult to mount this ?
They all will be from 1000usd to 1200usd delivered to Norway.
1way, 1.5 way or 2way - i dont really know the difference here :D
https://www.sau.com.au/forums/topic/234510-new-diff/
Basically:
1-Way: Diff is only locked on acceleration.
1.5-Way: Diff is locked on acceleration and half locked on deceleration.
2-Way: Diff is locked on acceleration and locked on deceleration.
If your using it for drifting, get a two way. When it comes to brands, at the end of the day they all do the same thing.
The first time i installed a two way was in my own car, but i had a mate to help who had done plenty before. It took about 3-4 hours to do. I'd say it would be a bit difficult if you have not done one before, but if your a bit mechanically minded you should be able to nut it out.
https://www.sau.com.au/forums/topic/234510-new-diff/#findComment-4110168
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
