Charity Choice
87 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 300
Posted Images
oh.....right..dont I feel stupid :)
Dont fill up at newie then hahaha
I guess if you get off at M2 somewhere, theres plenty of servo's on the way from there mate!
IIRC - there is a shell servo near where we meet, but its been awhile since Ive been around that area
doof...wtf!?!?!?!
car that bad mate??
grab a lift with someone mate?
I'll see whereI am in the morning on the way ok?
yeah, won't start and no one knows why... no spark across the board
Yeah I'll try and grab a lift with Zilch if it doesn't work out... still wanted to drive though :)
Here's a good way to fix it;
-Get in it
-Turn the key to "on"
-Put it in neutral
-Get some passers-by to give it a small push so it starts to roll
-Turn the wheel so the car is going down hill
-Straighten the wheel up so the car will go straight down the hill
-Before it gathers too much speed, turn the key to "off"
-Take the key out
-Give the steering wheel a quick shake so it locks in place
-Dive out of the car and just let it go.
-Buy a supra
-lol
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
