R32 GTR has been full rebuilt with forgies, all the usual. Installed the engine started it set timing etc and drove 10ks and parked. Now car will not start. Wierd thing is it run for a coupla hours while we were setting it all up. No mechanical noise etc. Was missing on the way back on light to medium throttle which I figured could've been AFM's.
Engine turns over fine, tries to spark the first coupla rotations then wets the sparkies.
Things we've checked so far
- Fuel is getting thru. Maybe even too much, wet's the sparkies after a couple of turns.
- Have spark, tested with a coil out, although seems weak.
- Tried different CAS and set timing
- Tried different Ignitor (PCU)
- Removed and reseated fuel rail
- Tried different ECU
- Tried different Sparkies
- Reset Computer and TPS
- Checked Front mount hoses
- Cleaned AFMs
- Checked for kinks in return fuel line and fuel pressure
- Cleaned fuel filter
- Checked fuses
Car has:
Splitfire Coils
Stock ECU
Forged Pistons
N1 Oil
Fully Balanced bottom end
Head has been rebuilt and ported
Metal Head Gasket
Stock Injectors and stock pump
Did a ECU diagnostic come up with CAS, Knock Sensor and Ignition. Swapped the CAS and it cleared ignition and CAS, only knock sensor comes up intermittantly. There were a coupla grounding cables we missed connecting on top of the coolant inlet but these are connected now.
I've been thru every post I can find but can't find anything I haven't already tried. Any ideas of what else to check would be much appreciated.
Cheers,
J
https://www.sau.com.au/forums/topic/234572-32-gtr-not-starting/
CAS is in the correct position? Locating key in end of exhaust cam is still there?
Leaking injector(s)? What is the fuel pressure?
REPLACED fuel filter?
Camshafts still aligned correctly (not skipped a tooth on the belt)?
What spark plugs?
The knock error is because of a fault in the knock sensors, not because you have knock. But it shouldn't prevent the engine starting.
Yes and Yes. Spins freely.
Injectors were tested professionally before install we've taken em out since anyway and put em up to the air compressor no leakage. Fuel systems all stock (injectors, FPR, pump) we've taken the hoses off and run the pump. Plenty coming thru.
Haven't replaced it but you can whistle thru it. Besides fuel's getting in fine. Covers the sparkies.
Haven't taken that off yet, I'll have a look but it was all on tight and running a coupla days ago.
What spark plugs?
Tried iridiums and standard BCPR6ES coppers. Iridiums are a 7 I think, they were working in the car before the build.
Yeh, figured that. Just thought I'd mention it.
Oh and we've tried running it with another car + battery so it should've had plenty of juice to start.
Cheers,
J
I'll try WOT start when I clean the plugs again.
Fuels only a coupla days old now was pretty much empty when we put the engine in, so put some new stuff in, but it did start and run for a coupla hours on the original fuel before that. Filter and lines appear clear, and it pumps thru fine when we disconnected the rail.
Tried the WOT start, no go. Tried to fire twice as usual then flooded the plugs.
We took out all the plugs and coils grounded em and rotated the CAS manually, it's weird 1 and 6 spark strongest the other's spark occasionally. Possibly the coil harness but a bit strange as it idled fine for a coupla hours when we were setting and testing it.
Thanks for the suggestions sofar. Any other ideas?
Edited by mojave15
Yeh, we held it, it doesn't get to the coughing fit tho. Just spins sounds like it's trying to ignite twice and then floods the plug.
Would anything else have an effect on the spark other than the ignitor. We rotated the CAS manually you can hear the injectors clicking open normally, but the sparks just seem really weak. Only 1 and 6 seem to spark with any consistency. Things doing my head in now.
Another post said something about a relay next to the ECU causing a similar prob. I can't find any other info on it tho.
have you mesured the voltage on the afm while cranking to make sure its not the afm besides cleaning it, because if its stuffed and mesuring like 3 or 4 volts then its going to be adding wayyy to much fuel to start
AFAIK you should still be able to run the car with the AFM's disconnected. We've tried that, I'll check the voltage tomorrow.
Tried a different coil harness today as well as measuring the fuel pressure. Sitting on 275kpa no restriction on the return line.
Guess I'm gonna have to recheck the timing, don't get how it jumped teeth still feels tensioned all fine. Everything was done up to factory specs. weirdest prob I've had yet.
Cheers,
  • 1 month later...
Gotta make sure you tension the belt correctly accross the section that goes from the crank back upto the top. Checking the other side is a false reading. Also you MUST wind the engine over at least 2 revolutions once you initially set the belt tension. Then recheck all marks and crack the tensioner bolt again and let it reset or make your own final adjustment.
I also think you are very lucky not to have bent any valves with 4 or 5 teeth skipped.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
