Mine does it..after long trips it does it even louder...very clearly audible. But the clutch feels fine.
I think it sounds like a hinge or a rubber seal sumwhere which needs to be lubed up :cool:
Wouldnt worry about it....
i wouldn't do that!!!
think it is under the bell housing cover, where the clutch engages and disengages, there is a sline there that needs lube i believe!!
if you have doubt email www.uniqueautosports.com they fixed it on my car!!
its the slave cylinder inside the box, i had mine replaced, if ur thinking of replacing it wait until u have to get ur clutch done aswell, save u alot of money, when mine was on its way it started to make a funny noises, not all the time, it use to whine alot, ps wd-40 is loosen bolts and to lubricate moving parts to an extent, its not the best lubricant, it dries up to quick and the squeaks will come back, u can by better sprays for lubricating, dont use wd for lubricating moving parts
silverskyline the slave cil is not inside the g/box , its on the outside on the bellhousing .whatever u do never spray any lube on the cluch or pressure plate cause that will make it slip.
u can lubricate the pedal and fork and the thrust bearing if u could get to it but as it is inside the bellhousing u have to remove the g/box to do it and if u do that u may as well put a new clutch , pressure plate thrust and spiggott bush and while u r at it machine the flywheel too .
if you leave it for too long it will eventually where the sleeve out and cause bigger problems thats what happened to my old car. Also if u have a heavy duty clutch and have been riding it, it will squeak. But you all sound like you know its comming from the pedal.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
