1. Complete R33 front cradle with callipers roters hubs powersteering rack lower control arms wishbones and suspension $300
2. rear R33 cradle complete with LSD diff hicas all arms brakes suspension $300
3. R33 Pedals for manual conversion clutch and brake master and slave silinders tail shaft $200
4. Dash and glove box $80
5. Standard front seats $150
6. Seat belts x4 +trims $100
7. Back seats $20
8. roof liner nonsun roof $50
9. Rb20 wiring loom minus coil pack part $100
10. Rb20 air flow meter out of laurel $80
11. Rb25 engin mounts one side has ally bracket other is missing $50
12. Rb25 oil return line off turbo $20
13. Rb25 Starter motor $50
14. Rb25 throtle cable and pedal $40
15. Rb25 Ac pump $30
16. Rb25 alternator $80
17. R33 doors drivers and passangers doors maroon with glass no door cards drivers side motor broken $200pair
18. R33 boot plus wing $100
if there is anything else i have missed just ask
Item Condition: Good
Price and Payment Conditions: $cash
Pictures: if required
Contact Details: Lucas 0421938098
Edited by #1rolla boy
https://www.sau.com.au/forums/topic/234639-r33-parts-galore-gold-coast/
hey mate when u say front cradle is that the front cross member.
your dash doesnt happen too have airbag . or airbag in steering wheel.
dont got any other stock stuff like exhaust airbox radiator front guards carbon canister ?
front cross member is part of the front cradle no air bags have 3 1/2 inch exaust cat back with muffler and cannon with 4inch tip good condition $250 not to loud makes good note
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
